Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear range max keeps dropping signal
I have a powerline ethernet connection to my PS3 everytime my wife gets on the computer that has a direct connection to the router the signal gets so weak that my PS3 disconnects. Why does this happen? How can I fix?
Is it cable or DSL? Cable should be fine but DSL gets slower everytime a second or third connection is added.
Posted on Jan 08, 2009
Dropped internet and NAS access
Try changing the channel.
you'll have to logon to the router - best to google the make/model for IP address etc.
Jan 23, 2014 | Computers & Internet
The middle ight keeps blinking and it wont work how do i fix it
Blinking middle light indicates an issue with the powerline used between the powerline adapters. To isolate the issue plug both the poweline adapters in the same room and check the lights on them. If they work fine in the same room then the issue is with the powerline. You may have circuit breaker, surge protector between the powerline adapters and that will prevent you to get a connection.
Hope this helps.
Regards
Anand
Mar 12, 2010 | NetGear XE102 Powerline Ethernet Adapter...
I have MacBook and it is not recognizing the ethernet connection
1. First check the light status of the XE102.
2. Then hard reset the Xe102
3. As this is a plug n play device all the lights should come on.
4. In case if the lights wont come on.
5. Check the powerline ..
6. And if that will not work , get a new adapter or replace the existing one from netgear ( 1-888-638-4327 )
Jan 26, 2010 | NetGear Powerline XE102 Ethernet Bridge...
Netgear WGX102 Powerline HomePlug wireless ethernet bridge dead
My friend, reward your year of hard work with a new router. Yours is dead.
Dec 11, 2009 | NetGear WL |WGX102 RANGE EXTEND R Bridge
No lights come on when I switch on my XE102.
Though, it is not repairable, yuu may contact NETGEAR to get the unit replaced if it is still under warranty. Contact them http://my.netgear.com
Regards
Anand
Aug 08, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Verizon modem/router and Netgear WGR614v9 On Demand setup
  • the modem and router must connected
  • either you use a long ethernet cable to connect the tv to the router or use a powerline to extend the router.
Jul 31, 2009 | Actiontec (GT704WG) Router
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear FE108 connections
You must configure the other PCs in the same IP range of the netgear. fexample: if the netgear ip adress is 10.0.0.1 then the other PC should have an IP like 10.0.0.x (x = any number from 2 to 254)
Sep 24, 2008 | NetGear FE108 8-Port Ethernet Hub...
Netgear ethernet xe102
You have to be on the same transformer leg Xmitter and reciver try moving the input device to a diffeent outlet. or use one of the ethernet only units to see if you have etherne tconnectivity, also there is a pricatical distance limitation of about 600 feet. are you in that range. Best of Luck Graeme at ctcco.com
Oct 09, 2007 | NetGear XE102 Powerline Ethernet Adapter...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
312 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
