Question about Dishwashers
Whirlpool dishwasher part #3385181. Machine had gone thru wash cycle and was starting to dry. Smelled electrical burning smell, opened washer door and washer was filled with smoke. Turned everything off, cleared smoke, and the washer water dispenser is very hard to turn. Washer has symptoms of burnt up motor that turns water dispenser. Machine is 12 years old. With cost of replacement motor and possible part (pump?) that might have clogged and caused motor freeze up, is it worth fixing or junk it and purchase new one?
    New Friend:
  • 124 Answers
Be grateful it didn't burn the house down.
Replace it.
Cost of parts will outweigh cost of replacement.
Posted on May 14, 2017
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
  • 175 Answers
SOURCE: Dishwasher began smoking
hi..the reason to this problem is probably due to the
bad need to replace it with a new one.
check this out..
thank you..
kindly rate my response..
Posted on Jul 21, 2009
SOURCE: Bosch Dishwasher Classix
I've had the same problem TWICE. It seems the natural vibration of the machine loosens wire nuts and leads to the problem. Soldering the connection and then placing a yellow wire nut over the soldered connection works fine to stop the problem. This machine has a electric water heater to sterilize the dishes and draws a lot of power, near the limit of the connection, more than a standard dishwasher. I called Bosch twice about this problem, only the second time when I stated that my lawyer might call them back did they admit that there is an issue with the vibration of the machine leading to the wire nut becoming loose and suggested I solder the connection. Great dishwasher, lousy customer service. They have know about this problem for years.
Posted on Nov 07, 2009
  • 86 Answers
SOURCE: Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Posted on Nov 28, 2009
  • 311 Answers
SOURCE: when dishwasher is turned on to the cycle mode -
The impeller on the wash pump is worn out or the disposer screen is obstructed. Disassemble as needed to investigate the cause.
Posted on May 28, 2010
Dishwasher has a terrible odor in it. I'm guessing it came from an empty sauerkraut glass jar and lid I put through the wash, heated dry and sanitize cycle. How do I get rid of that nasty, something...
Check whether the smell comes from the main drain. Pull your dish washer drain hose and check.
Leave dishwasher door open for few hours. Hope no rate has died inside the machine.
Run a empty wash several times!
Sep 26, 2010 | Whirlpool Dishwashers
I wash the DW with finish DW cleaner.All items smell rotten eggs
Try running a wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
Good luck
baby fluid also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks).
Jul 08, 2010 | Bosch 24 in. SHV55M03GB Built-In...
Lost power to washing machine
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Horrible smell coming from the washing machine
Have you cleaned the filter in the washing machine?
Mar 31, 2009 | AEG 24 in. Favorit 40660i Built-in...
Smell in LG LDF8812ST
First, scrape your dishes clear of food before putting them in.  Rotten food makes smells.  Second, use a good brand of detergent in the recommended amount and use the heating cycle to heat the water up.
Most dish washers have a dryer heat cycle but this one apparently does not.  This may cause mold in the machine.
How to get rid of the smell:  With no dishes in the machine, add half a cup of bleach in the bottom of the unit and do a full wash cycle.  If the unit still has an odor, get some baking soda...about a half cup and put that in the bottom of the machine.  Close the door and leave overnight.  Then, run the machine through one wet cycle...say a wash cycle and then it should stop smelling.
Hint:  When leaving dishes in the machine between uses, leave the door not close tightly.
Nov 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
My washing machine has a bad smell and wont work
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Oct 20, 2008 | Whirlpool AWM5125/1 Front Load Washer
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Mar 21, 2008 | Dishwashers
Smell of burning
The Element is shorting out, tripping the rcd. replace the element, thermostat,and any cut outs that are in the element cricuit. The element should not be glowing which means the stat is shot and the safety cutout for the element is shot also, while you`re at it check out the circuit board for dry joints, discoloured resisters, bulging capacitors etc.
This is VERY dangerous situation, as the machine has the potential to set your house alight and burn it down!. If you continue to use it in it`s current condition you may well damage other componants - rendering the machine B.E.R - Beyond Economical Repair. I will will advise You to never to leave this machine unattended, do not go out after turning it on and have a nice afternoon in the park etc, you may well come home to a pile of ashes!
Feb 18, 2008 | Zanussi ZWF1430W Front Load Washer
E40 error code
The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Dec 16, 2007 | Zanussi ZWF1440 Front Load Washer
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
