Question about GPS
Garmin 405 pair to wrong HRM
The first time I used my Garmin 405, I didn't use the HRM strap. It paired itself to a running partners HRM strap (I can see the HR data) and know I cannot get my 405 to recognize my HRM strap. Is the 405 mated to the other HRM strap indefinitely? or is there a way to make the 405 find the new HRM strap?
thanks!
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80)
Posted on Jan 18, 2010
Garmin Edge 705 Heart Rate Monitor Not Working
It could be that there is a failure in the circuit between the two pads on the chest strap and the HRM electronics in the middle. If it won't work at all try putting the battery in backwards for a few seconds (this is supposed to accomplish a reset) and then try re-pairing it with the Garmin. If this doesn't work, I suggest a new HRM. I've hadevery good luck with my Wahoo TICKR and a Garmin 502.
Mar 24, 2017 | Garmin Cycling
Garmin Forerunner 405 Broken Clasp
Unfortunately there is no way to fix this. All you can do is to follow this link and order new strap from two available(at the bottom of the list):
https://buy.garmin.com/shop/shop.do?pID=11039#accessoryTab
Rate me, please.
Jul 23, 2009 | Garmin Forerunner 405 Sports Watch/ HRM
Cadence does not register on edge 705
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Jul 14, 2009 | Garmin EDGE 705
Can't pair garmin forerunner 50 with hrm and food pod
First you have to assume the battery that comes with your HRM would be new - keep in mind that it may be stored in the warehouse for many moons.
Given that, open and take out the battery - that should make a hard reset on the HRM itself. Restore the battery and try the manual pairing again.
The heart icon should pop up again.
Otherwise, you have to suspect the battery is low and need to be replaced.
Good luck
Jun 05, 2009 | Garmin Forerunner 50
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
I bought a Forerunner 50 with HRM and Footpod. Initially the footpod wouldn't work, but HRM would. So changed the battery and footpod is fine. However, HRM now won't work. Just replaced the battery in that...
I had a similar problem. First my hrm worked and the footpod did not. Then I tried to pair manually (for the umpeenth time) when the hrm was too far away, and I lost that pairing, and it still didn't find my footpod. Then I wet the hrm sensors and tried pairing again and then it picked it up. Finally, I switched batteries in the hrm and footpod and then it picked up the footpod. Now I'm headed to the store to stock up on batteries. Kinda upsetting that I have to buy batteries when I just got the thing, but probably costs less than the postage for sending it back!
Feb 21, 2009 | Garmin Forerunner 50
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Can`t pair Garmin Forerunner 50 with footpod
I've been having the same problem. I couldn't pair my footpod, but my heart rate monitor was working. I've only had the 50 for about eight weeks.
I reset the watch, holding view mode and Start/Stop at the same time.
This didn't do any good.
I swapped the battery in the HRM with that in the foot pod. The foot pod synched the HRM didn't.
Solution duff battery. I'd change yours it will probably do the trick.
Hope it helps
John-Paul ( AKA OldGreyWizard)
Jan 10, 2009 | Garmin Forerunner 50
HRM troubleshoot
A HRM is a training tool that helps you do cardiovascular (CV) training correctly, neither too hard, nor too easy. It’s almost like having a personal coach on your wrist! Every HRM comes in two parts: 1. An elasticated chest strap which contains a pair of sensors that detect and transmit your heart rate. 2. A wrist worn receiver that receives the signal from the chest strap and displays your heart rate. The receiver may also have additional functions and display other information depending upon the HRM model chosen. Both the chest strap and receiver are battery operated.
Aug 27, 2008 | Welch Allyn Spot Vital Signs Monitor
GPS Logo
287 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
