Question about Nokia 7270
Battery problems plug in the charger and the phone will go through the charging process and say it's fully charged but as soon as you make a call the phone turns off. When you turn back on the battery says it's only charged to 1 bar. Then if you try another call it turns off again.
  • mykaiyadog Jan 04, 2009
    Thanks for trying. The problem is that I have 3 batteries. 2 new (which were fully charged) and an older one I've used in another phone for months. The battery doesn't have any problems in the other phone. I'm thinking there must be a problem with this phone that it drains the battery.
  • 492 Answers
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Posted on Jan 04, 2009
Why won't it turn on?
plug it in to the charger againm, it may show as charging and come on. If it does your battery needs to be replaced. A battery can show fully charged on charger nut not hold the charge when removed
Aug 09, 2015 | Cell Phones
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Htc wildfire not fully charging always show the led red
When want to charge htc wildfire it is better you turn the phone of before charging. Plug in the charger and charge for about 20mins to 30mins then remove the charger pin-mouth for like 10secs and plug it back in. soon the red light will turn green in less than an hour..
Jul 16, 2012 | HTC Wildfire
How will be i identify it is fully charged battery i charged for 45 minites.But the battery will not be fully charged. please send me the solution for this problems
If using usb charger use usb port on back of desktop, not data port in front, also most laptops do not have fully powered usb ports due to battery consumption. The wall charger, or a usb charger plugged into a usb/ac adapter (like included with ipods and kindles or sold seperately) is your best bet for reliable charge.
Charging unit should have a light on it.
When charger is plugged into power source and not helicopter, the light will show you {#1} what it looks like when battery is fully charged. Typically this is steady on, and usually red. (sometimes green) When you connect helicopter to charger, the light will change (usually goes dark) to signify it is charging {#2}. When light comes on fully (or completely returns to #1) then charging is done. (Note: charging using a laptop usb or a front side data port usb can take several hours.) Watch the light on charging unit when you unplug helicopter, if it gets brighter, helicopter is not charged, plug it back in. Make sure to let battery cool for 10 minutes after every charge and 10 minutes after every flight, and never run battery all the way down. As soon as you can't maintain altitude, land and power off. Fully draining a Li/Po battery weakens it's ability to hold a charge and can ruin it.
If all else fails, replacement batteries are available from Amazon and many others, they are cheap (around 5$) and very easy to install with no soldering and just a small screwdriver.
Hope this helps
r
Dec 31, 2010 | SYMA Toys industrial Syma S032 Ready to...
1110 how to sold not charging
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
Jul 22, 2010 | LG Vu CU920 Cellular Phone
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
Cect i9 wont charge battery is fine
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
Dec 10, 2008 | Dual Electronics CECT P168 Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Draining battery
This camera has had problems with the primary switch block faulting. The camera will power up all by itself when unattended and drain the battery. Another symptom would be the battery refuses to charge fully because the camera must remain in the "OFF" mode for the charge process to begin. Sony in Laredo, TX is replacing these controls at little or no cost, I would call them to see if they will repair this for you. Hope this helps you. Joe Weibel Custom Electronics (customelectronics.org)
Feb 11, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Nokia 7270 Logo
253 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
