Question about Toshiba Satellite P15-S479 Notebook
Not booting from hard drive or dvd-ram
Basically the laptop will not boot from the hard drive, and it will not boot from a cd also.... I don't know how to fix this issue and need serious help! If you can help I would greatly appreciate it, I also keep getting a message "Intel UNDI, PXE-2.0 (build 082)
Copyright (c) 1997-2000 Intel Corporation
For Reatek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM."
So Please Help me!
  • Christen B. May 11, 2010
    Have you tried logging into the bios and checking the boot order told it to boot from the hard drive?
  • 201 Answers
If the cd rom is bad it will do that
Posted on Jul 20, 2009
What is the boot order for acer aspire 7741
To use the Acer recovery CD you need to boot up with the CD.
Go into the BIOS setting and scroll through the settings until you come to Boot order. Then move the CD/DVD drive up as the first boot device and the hard disk as the 2nd boot device.
When you boot up the Acer with the recovery CD in the CD/DVD drive then it will boot up with the Recovery CD.
Jun 17, 2012 | Acer Aspire 7741G3647 (LXPXB02046) PC...
Pxe e53 no boot filename received
Sounds like it is trying to boot from a lan or someplace other than your hard drive. Make sure you don't have a music cd or movie dvd in the cd/dvd drive. Turn the computer off then turn it back on and the screen for which key it says to hit to Change The Boot Sequence or Boot Order, then hit that key. You have to hit the key when you see the message or it will not work and you will have to reboot and start over. Select the Hard Drive as the boot device and let it boot up. If you are successful then each time you boot you will need to do this process unless you make it a permanent change.
To make a permanent change to the boot process turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup, then hit that key. You have to hit the key when you see the message or it will not work and you will have to restart and boot again. Once you are in the Bios or System Setup look for any reference to Boot, Boot Sequence or Boot Order. It might be a tab you you select at the top of the window. Change the boot order to CD\DvD as 1st and the Hard Drive as 2nd. This is the normal boot order so that if anything goes wrong with the hard drive, you can boot from the cd/dvd by putting in a repair disk or operating system disk. Just make sure you don't have a music cd, movie dvd or anything in the cd/dvd drive when you boot. Save the settings and exit the Bios or System Setup and Reboot.
Jun 05, 2012 | Intel D946GZIS Motherboard
I dont know how to set boot option?
Normally you want to boot from the CD/DvD drive 1st then the Hard Drive 2nd. This is the best way because if the hard drive ever goes bad you can put a operating system disc or repair disc into the drive and boot from it.
Just be careful that when you boot the computer you don't have a music cd or movie dvd in the drive otherwise you might get an error messages saying unbootable device.
May 13, 2012 | HP Compaq nc6000 Notebook
No bootable devices
Make sure you don't have anything in the CD/DvD Drive. It sounds like your system is trying to boot from something other than your hard drive.
Turn the system off then press the power button to restart it. Watch the screen for which key it says to hit to Change the Boot Order or Boot Sequence and hit that key when you see the message. Select the Hard Drive as your boot device and let it boot up again. This is a temporary change that is only good for the current boot cycle.
It the system boots then you want to restart the computer and this time watch the screen and see which key it says to hit to get into the Bios or System Setup and hit that key. When it opens tab over to the Boot and set your boot order or boot sequence to have the CD/DvD drive 1st and your Hard Drive 2nd. This is the normal way so that if your hard drive ever fails to boot you can put a cd in the drive to remedy the problem. Otherwise, just make sure nothing is in the cd/dvd drive when you turn the boot the computer.
May 13, 2012 | Dell Inspiron 1525 Laptop
I have a HP Pavillion Entertainment PC that will not start up. Two new motherboards have been placed in it and it will still not boot up. It starts up and then just shuts down.
ok, this is a muti step process. 1. Remove the hard drive and push the power button. When the HP screen appears enter the Bios. This is usually done by pressing ESC, Del or F1 when the computer displays the HP screen. If you get into the Bios open and insert a bootable CD/DVD close the drive door and let teh computer continue to boot. If you don't have a disk handy you can get Knoppix, a Linux OS designed to run from DVD/CD, at most used book stores for about $5. If the computer starts your problem is the hard drive. 2. Assuming the computer did not boot. With the hard drive out, remove the RAM and repeat the steps above. 3. If the computer still fails to boot remove the CD/DVD drive and repeat. At this point you can reinstall the hard drive and RAM. Your goal here is to remove items until you locate the one that is causing the problem. Since you have already replaced the motherboard a second time you are pretty sure your main board is good so it must be a different device. The most likely fault is the Hard Drive followed by RAM, CD/DVD drive, MODEM, WiFi and so forth. Once the computer boots with a specific device removed you know that device is at fault and replace it to resolve the issue.
Aug 05, 2010 | HP Pavilion dv6000z Notebook
My laptop wont boot. It makes a loud whirring
take whatever CD you have out of the CD/DVD drive. You might have the boot order set to CD first. If that's the case, it's trying to boot from your CD drive instead of your hard drive.
Feb 19, 2010 | Toshiba Computers & Internet
I have a blue screen with no text at boot, it shows only after i do bios fingerprint check, in order to get acces to windows 7 i have to turn on and off couple of times, i do cd dvd boot, hdd and fdd boot...
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Dec 10, 2009 | Toshiba Qosmio F45-AV412 Notebook
Booting probs
go to boot sequence in the order
CD/DVD
Hard disk
others
Apr 23, 2009 | Compaq Evo N410C Notebook
I have a dell inspiron b 130 and my cd rom was pulled out by my son i wanted to know how can i boot my computer from the new cd dvd rom i need to format my laptop
you can configure it on the bios settings of the unit itself (possibly F2 or F11)
Then go to boot sequence then look for the removable device.
Then save your settings and restart your laptop. It should be working now.
Feb 26, 2009 | Dell Inspiron 8200 Notebook
Computer will not turn on
The only things that can do this are: A card failure, a hard drive failure, Motherboard faiulre, A Power Supply failure, Faulty RAM. To toubleshoot.. disconnect Hard Dive, CD/DVD remove any & all cards, see if it boots,if it does, add the Hard Drive, reboot, then add the CD/DVD, reboot, then replace A card, reboot & so on... until ya find the faulty component, that stops it. If it doesn't remove ram & see if it powers up, it will NOT boot. If it doesn't ya PSU is most probably faulty. If it does ya RAM/motherboard is faulty. So basically strip it down see if it powers up. than add things one at a time to find the culprit.. then replace the ofending item.
Aug 06, 2007 | HP Compaq Ethernet Switch
Toshiba Satellite P15-S479 Notebook Logo
547 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
