Question about Maytag MER5775Q Electric Kitchen Range
I have a Maytag MER5775Q Electric Kitchen Range. Everything on the range operate properly except for the oven. While it does get warm, the highest degree of heat that I have seen it obtain is 200 degrees when the temp was set to 350. I originally thought it was the heating coil, but I was told that if it was the heating coil, the heat would not work at all. Does anyone have any suggestion on how I might fix this problem? Thanx
  • 8 more comments
  • Randy Nelson May 19, 2007
    I really appreciate you taking the time to try and help. I did a little more looking myself and noticed a build up on the element. When I tried to clean it off the element broke. I just got back home with the new element, and will install it soon. Again, Thank You.
    Randy
  • Anonymous Nov 04, 2007
    my oven takes 2 hours to heat i think it is the same problem...top element..{broil element} is only way to heat oven.....after biscuits were done the bottom of biscuit was not discolored as previous cooking experience. no heat from bottom of oven could cause slow preheat.. and no crisping on bottom of biscuit shows only top element was on .. as top of biscuit turned brown...does anyone want to try to help me figure how to test elements...not sure about bypassing thermostat...all other features work fine.
  • Anonymous Mar 17, 2014
    maytag model 8114p732-62 electric range won,t heat up
    maytag electric range model 8114p732-60 won't heat up
  • Anonymous Mar 20, 2014
    Since the day purchased our Samsung Range does not heat to the temperature set. Often it reaches a certain temp and quits. Other times it says 400, but is only at 250. I've tried everything and nothing works. Samsung states that they have never gotten a complaint like this, but the internet tells a different story. Closest tech is across the country. How can I fix this
  • Anonymous Mar 22, 2014
    When the oven says its 400 degrees its still actually 300 degrees.
  • Anonymous Mar 25, 2014
    we thought the element went out bought another one it heats at 350 then only stays warm
In the Maytag Mer5775 series, if the thermostat proves not to be causing the problem, then It most likely is caused by a defect in the clock. It totally suprised me when I found out that since the clock got knocked out by a loose wire that sparked and shorted it out; the oven on my newly installed Mer5775BAB will not work at all. The range top works, but the oven will not work until the clock is replaced. The service man ordered a new clock 7 days ago from Maytag and it still has not arrived yet, I was told it possibly could even take another whole week.
Posted on Sep 19, 2007
    President:
  • 1,462 Answers
Heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
Posted on May 18, 2007
SOURCE:
My maytag range broiler works and stove top but not oven what could be wrong
Likely causes are;
Oven element faulty - needs to be tested;
Burnt wiring at oven element terminals - visual inspection;
The electronic timer is set to auto. mode - must be in manual mode.
Feb 18, 2011 | Maytag MER5775Q Electric Kitchen Range
Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
MAYTAG ELECTRIC OVEN MODEL MER5755QAS OVEN WILL HEAT ABOVE 250
the mostlikey cause is a faulty contorl module as well as the thermostat i make a habit of changing them both
Sep 16, 2009 | Maytag MER5775Q Electric Kitchen Range
My oven is taking a really long time to warm up. it has been over half an hour and it is only at 180 degree
You may need to replace an heating element, it has 2 the top one (broil element) the bottom one (bake ele)
First try shuting off the breaker to the range for 45 min, this will reset to factory settings
Jul 07, 2009 | Maytag MER5775Q Electric Kitchen Range
Oven won't heat
25 mins for oven to reach temp is not unusual. if it reaches temp ok across the range, don't think you have a problem
Apr 16, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
534 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
