Question about Whirlpool Washing Machines
Wirpool duet sport washer model wfw 8300sw05 add garment flashing,press pause clear will not clear door will not unlock and search for error code show code 24,26 and i replace heath sensor and door sw
Elf i need to do to get it work. thanks
3 Suggested Answers
  • 12 Answers
SOURCE: MY DUET SPORTS DOES NOT DRAIN.
your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
Posted on Sep 14, 2009
Jahn27
  • 1554 Answers
SOURCE: whirlpool duet sport washer add
This symptom characterizes a problem with a faulty motor control unit (MCU). It has been found that a fault in the MCU can lead to erratic operation of the machine with or without error codes being flashed. It can be verified by isolating the MCU, that is disconnecting it from the central control unit (CCU). If the machine seems to work fine with the MCU disconnected except motor powered functions, the MCU is indeed the problem and the only viable solution is replacing it.
Unplug the machine or disconnect power then remove the three screws from the rear of the machine top cover. Pull back on the cover and release the tabs in the console from the slots in the cover then lift the cover off the unit.
Locate the CCU then disconnect the MCU harnesses marked MS2 and MI3.
Reconnect power then start the machine. Replace the MCU if the machine seems to work fine except motor powered functions. Otherwise, let us know for further advice.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Aug 01, 2011
Whirlpool Duet washer - paused cycle to add a garment now can't get it to resume cycle or clear the cycle.
I did as Drunan did and unplug for 10 and plugged it back in and it started like a champ! Thanks!!!!!! ;)
Jan 16, 2012 | Whirlpool GHW9300 Duet Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Kenmore h2 error code
Jan 11, 2010 | Kenmore 46462 Front Load Washer
Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool ghw9100lw the light is flashing but it will not start
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
I have a Whirlpool Duet Sport, brand new. It keeps asking to add a garment when the washer is jam-packed with clothes. Is it a malfunction, does the "add a garment" light ever shut off?
the add a garment light will stay on through most of 1st wash this lets you know that if you forgot something it can still be added ..if not already overloaded..by pressing pause the door will unlock and allow something to be added ..yes it's normal
Aug 10, 2008 | Whirlpool Washing Machines
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
