No power at all to anything
SOURCE: Hotpoint RVM 225 BL 002 power reset. Internal breaker?
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
I would suspect the fuse or magnetron thermostat.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: HOTPOINT COUNTERSAVER PLUS RVM 1435 DISPLAY READS F3
"F3" on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On RVM1435-series microwaves, the membrane keypad is not available as a separate
part, so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a
simple do-it-yourself job.
You
can find helpful exploded view diagrams and order parts by entering your full
model number (RVM1435XX###) from the tag on the oven
here.
At
our Web site, we have a video available showing how to remove a typical over
the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board
into your frame.
Some connectors on the relays have a lock:
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating of our
answer.
