Question about Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N
Noritz tankless water heater not producing hot water
I have had a Noritz N-069m tankless water heater for the last 3 years. When I turned on my hot water today, I noticed that it was just trickling out of the faucet. I checked the hot water heater and it is blinking error code 16. Any idea what this error code indicates? Their customer service is not open and I would rather not wait a day or two to find out what the issue is.
  • 2 more comments
  • ross_fairy20 Jan 11, 2009
    my tankless hot water heater is not workin i need help today
  • Les922 Feb 17, 2009
    exactly the same.  the water tricles then code 16 comes on.  what can I do to stop this?
  • Lochsa May 02, 2009
    I hear ya! Have the same problem and cannot find what error code 16 is.
    frustrating!
  • Anonymous Mar 26, 2014
    can you use a noritz tankless water heater vent kit for a kenmore water heater; same size vent?
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
  • Kimberley
    Kimberley Apr 24, 2014
    I did this and it worked for a week and it shut off again today with error code 16. how do you adjust the manifold pressure?
    Scholar:
  • 71 Answers
Likely pilot is out; I hope it is repaired by now.
Posted on Jan 06, 2009
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
Error 71
EC 71 usually means you are using a battery backup that doesn't produce a pure sine wave. OR you recently had a power outage and it shorted the circuit board. if you have a battery backup try unplugging that and see if it works okay. If not, just call Noritz for a replacement c/b.
Dec 06, 2013 | Noritz 6.9 Gallon Residential Tankless...
I have a Model N-069M and i get a flashing code 16. I just had the unit flushed two days ago and i still get the same code. thanks for any help
I feel your pain. I am experiencing the same issue which started about 3 weeks ago. First it happened twice that first week and we discounted it. Now that my heater has been flushed the same issue is occuring. I called Noritz 3-4 times now and they are saying that I may have high manollowifold pressure and should have that checked.
FollowUp: Plumber determined my Natural Gas inlet line was too small. He Tee'd off before my manifold to other appliances and fed with a 3/4 line. Issue resolved and it has been trouble free since. (Updated 2/2017)
Feb 12, 2011 | Noritz 6.9 Gallon Residential Tankless...
What does F-76 code mean on a Noritz M-069 panel
F76 is a communication error. It usually occurs if you connect or disconnect a quick connect cable or remote control when the tankless heater is connected to electricity. (If you have a quick connect system, make sure you only have 1 remote and 1 quick connect cable.) To get rid of the code, try disconnecting electricity for 20 seconds, reconnecting electricity, and turning the remote on. If the code returns, you may need to replace your quick connect cable, remote cable, or even remote control
Sep 14, 2010 | Noritz 6.9 Gallon Residential Tankless...
Noritz f 76 error blinking f 76 and on off light blinking at the same time. Everything works fine turned on and off hot h20 it goes to burner on 120 and then goes back to blinking f 76 after burner...
F76 is a communication error between two quick connected heaters. To clear the code, disconnect power from both heaters, wait 20 seconds, then reconnect power.
Apr 23, 2010 | Noritz 6.9 Gallon Residential Tankless...
After water to house was shut off, my Noritz tankless water heater is on but won't produce hot water. On the unit, the light indicating that the burner is on stays off now.
you probably had debris get into the filter or flow sensor when the water was turned back on. I'd recommend checking the filter first and if that doesn't work, call Noritz Tech support to help you with the flow sensor.
the filter is a black plug located on the cold water line (labeled cold on the bottom of the unit). It points torwards the left.
Apr 14, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I have a Noritz Tankless outside my home on wall for several years. Works fantastic until now. Controller is going blank intermittently. Able to restart after resetting GFCI, plugging and replugging. On...
It sounds like your GFI is tripping. There are two common reasons for this to happen 1) plugged into another GFI 2) moisture on the gfi. I'd look for evidence of a water leak which is tripping your gfi. Look for puddles, water spotting, water hardness, etc.
Jan 28, 2010 | Noritz 6.9 Gallon Residential Tankless...
First it takes over two minutes to get hot water 30 feet away. Then when it's finally hot and adjusted to a comfortable setting in the shower, it only lasts maybe 3 minutes. And in the same room, the...
If the unit is functioning properly, then you need to contact your utility company to see about upgrading the size of the gas line and meter to your house, and possibly the lines IN th house. It may be cheaper to go back to a tank type water heater despite the potential energy savings with a tankless.
Oct 09, 2009 | Noritz 6.9 Gallon Residential Tankless...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.9 Gallon Residential Direct Vent Tankless Water Heater - N Logo
3,845 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
