Question about AEG L88800 Front Load Washer
AEG 88730 error codes
Hi Does anyone know what error code C3 is and how to fix it. Thanks
  • 1 more comment
  • Jon Darby May 18, 2007
    Thanks for taking the time to post the link to a solution.
    Had my suspicions, but short of time and didnt want to dismantle the machine for nothing.
    Best wishes
    Jon
    Any time you are in Scotland, let me know.... www.hillview-cottage.com for great Stirling B&B near Edinburgh and Glasgow
  • Anonymous Mar 16, 2008
    error code c3
  • harrwaag Sep 30, 2008
    Problem with code c9 cen you help?
Error code c9
Posted on Feb 22, 2009
AEG LAVAMAT 86741 UPDATE RESET CODE.
HOLD DOWN ALL FOUR BUTTONS TO LEFT, AND TURN KNOB CLOCKWISE TO ENERGY SAVE. ALL LEDS WILL LIGHT UP, LEAVE IT FOR TWO TO THREE SECONDS THEN TURN OFF. THIS RESETS YOUR MACHINE. I SPENT 90 MINS TRYING ALL COMBINATIONS, RECOMMENDED AND OTHERWISE, NONE WORKED. THIS DOES. MY FAULT WAS C9. MOTOR BRUSHES. I REMOVED TAPPED OUT CARBON DUST,CLEANED AND CLEANED THE COM, REFIT AND USE THE CODE ABOVE.
Posted on Feb 25, 2008
Here you go http://www.retrevo.com/search?q=AEG+88730+error+code+C3&sub=Search
Posted on May 18, 2007
Error c3
http://www.aeg.co.uk/Support/Troubleshooter/?Command=Detail&CatId=98&SymptomId=1412&DetailId=1412shows AEG's meaning for a C3 error code
Feb 06, 2013 | AEG Washing Machines
I'm looking for free unlock codes for a nokia c3-01
Hi there are many online providers found that render codes to unlock mobile at free of cost but they provide codes only for older mobile models.To get codes visit prounlocking.com here they ask you the network provider name to which your mobile is locked .Finally they deliver you codes to unlock your Nokia c3-01 touch and type phone.
Jul 31, 2012 | Nokia C3 Touch and Type Cell Phone
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | AEG Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
Dishwasher keeps displaying c3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
If problem still persists, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | AEG Dishwashers
Error code C3
LOOK IN YOUR MANUAL...IT SHOULD HAVE A SOLUTION TO THIS CODE..JUST FOLLOW INSTRUCTIONS...BEST OF LUCK..
Jan 11, 2009 | AEG Lavamat Lavalogic 1600 Front Load...
AEG 88730 UPDATE
For a solution to your dilemma, I recommend that you first replace the brushes, then to reset the error code C9 hold down the pre-wash & short wash together and turn the control knob from off to gentle spin. this sequence should clear the C9 from your washer.
Aug 18, 2008 | Washing Machines
Aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
May 08, 2008 | AEG L86800 Front Load Washer
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG Dishwasher FAVORIT 3A Error Message C3
Oct 24, 2007 | AEG Dishwashers
AEG L88800 Front Load Washer Logo
5,536 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
