Question about Maytag MGR6775 Stainless Steel Kitchen Range
Maytag MGR6775 Gas stove. One igniter not working.
I have a Maytag Double oven/stove. When I try to ignite ONE PARTICULAR burner, I get no spark. When I use ANY other burner to ignite it, ALL the burners spark....So, only one dial does not produce a spark. HELP!!!
  • 10 more comments
  • samorrow Jan 04, 2009
    It ignites from any of the dials except one. When I turn the dial for the ONE burner...nothing happens but gas comes out. When I turn ANY other dial....ALL the burners spark. The problem is that I am having problems getting ONE dial to spark. All others spark. (BTW, when you turn ANY dial...ALL burners spark. That is normal)
    Where is the ignitor located and how do I get to it? (I imagine it is under the dial...just not sure how to get to it).
    Sam
    SO it sounds like the ignitor for that dial. How do I change it?
    When I tale off the caps, there are two phillip screws to take off the thing that the flame come out of. the metal sparker (ignitor) does not lift out. Also, why would the ignito light/spark using a different knob? That makes me wonder if it is the ignitor or not. It does spark when I use a different knob.
    Yes...It sparks with 4 out of 5 dials. 1 dial (the one that goes to that burner) does not make it spark. That's my problem. I have 1 dial that does not make the burner spark. I can light it by turning the dial on, then turning a second dial on to make it spark. What do you think it is?
    yes.
    That is correct. No clicks...just gas coming out.
    How do I test which one and how do I get to them?
    ok. I got the top off. I see a series of wires that runs down each dial. Where is the spark module and how do I test it?
  • Anonymous Feb 14, 2009
    Similar problem here on my MGR6775. I disassembled the cooktop, and discovered that all five ignition switches (the switches are attached to the valve stem to which the knobs are attached) are connected to the same two wires. These two wires switch on/off all five ignitors at the same time.
    A spill on my stove shorted out one of my ignitor switches and the switch caught fire. Way to go Maytag. Design a stove that catches file when someone spills soup on it. Really? Really???
  • mihulka3 Feb 22, 2009
    I'm having the same issue with my Maytag gas top. It's pretty much a piece of ****. Maytag is milking thier "previous" reputation for quality products.
  • seand99 Apr 29, 2009
    Same probem; one know does not trigger the ignitors (i.e. no clicking) the other knobs all cause all the ignitors to spark. How do I get that knob to trigger the sparks?
  • 530 Answers
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Posted on Jan 04, 2009
  • 13 more comments
  • erica graber Jan 04, 2009
    you probably have a bad ignitor i would replac e the ignitor that should solve the problem
    yes it is normal for all of the burners to spark. bbut only the dial that you are turning is letting the gas out. so only that burner will ignite when you turn the knob to ignite.
    the ignitor is the thing that sparks so what you have to do is take all the caps off of the cooktop. usually they are torque screws sometimes difficult to remove i usually poor some water on them and let them set for a minute. then i remove them. Depending on your modle some of the caps twist of. make sure you turn your poweer off. verify if there are torque screws or no screws
    If you have the twist off kind yyou can access the ignitor very easy. you will see the wire that goes to the ignitor. you just have to take that off and i believe there is one screw. then the ignitor comes right off.
    If you have the kind with the torque screws you have to take all burner caps off and pop the lid up to access the ignitor
    oh it does spark i thought it did not. so
    is there gas comeing out of the orfice when you turn to light?
    when you turn the dial that is not working do you here a click or no clicking sound just gas comeing out?
    since you know that the ignitor is good it is a possible bad spark modual or switch that sit on that individuall gas valve
    I would say more likly a bad spark modual
    depends on the model sometimes the spark modual is in the back of the unit usually it is a dark orange color. trace the wires that go to that ignitor to spark modual and see if therre is 120 volts getting to it if so then you know thats your problem. usually i check from one leg to groundd ofr nutral if you can find a nuetral. some models have there own seperate modual for each ignitor usually they are blue. it looks like a square box
    if you do not have 120 volts. then you have a bad switch that sits on the valve itself its white and has 2 wires going to it ususally a red and a black.
    turn the gas off first when doing this check. because you have to turn the switch on first. when checking the module.
    also if you can swap one of the ignitor switches with another that is a good way of eliminating the valve switch.
    I hope this was helpful.
    sorry i ment to say valve switch not ignitor switch
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
Maytag gas stove model CRG9830CAE the oven will not work
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, the igniter needs to be replaced. Good luck.
Mar 27, 2010 | Maytag Kitchen Ranges
Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
Oct 16, 2009 | Maytag Kitchen Ranges
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
The dial on my maytag gas stove shorted out
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Nov 30, 2008 | Maytag MGR5765QDS Stainless Steel Gas...
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
All 4 ignitors just stopped working on the stove top...no more 'clicking' sounds
1 Check to be sure unit is properly connected to power supply.
2 Check for a blown circuit fuse or a tripped main circuit breaker.
3 Check to be sure ignitor is dry and clicking. Burner will not light if ignitor is damaged, soiled or wet. If ignitor doesn’t click, turn control knob OFF.
4 Burner ports may be clogged.
Dec 03, 2007 | Maytag MGR6775 Stainless Steel Kitchen...
Open Questions:
Maytag MGR6775 Stainless Steel Kitchen Range Logo
1,749 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
