After formating system getting very slow and if i cancel the improprer shutdown scaning it will go faster pls helpme slove this problem
  • 1 more comment
  • Nathan B
    Nathan B May 11, 2010
    With this little amount of information, I would suggest the hard drive's life is coming to an end.
    Does your computer have a lot of blue screen moments?
    Once your computer loads windows again, I suggest you try a defrag.
    Here is how its done.
    Windows XP HOME/PROFESSIONAL
    1. Click Start
    2. Click Program
    3. Click Accesssories
    4. Click System Tools
    5. Click Disk Defragmenter
    Once the program loads click the analyze button and it should tell you if it needs to be defragged or not. If it needs to be defraged than click DEFRAGMENT
  • TDDW
    TDDW May 11, 2010
    First of all, How old is your system? Second, are you installing the same OS that was originally installed on the system? Third, How much memory is on the system? With out having a bit more info, I can only give you a general answer.
    1) You may want to upgrade system bios if you have an older system.
    2) Check amount of memory for the OS you are running.
    3) Make sure that you did not introduce a virus when re-installing your applications.
    4) More info is required for a proper diag
  • Thomas F. Schneider May 11, 2010
    Are you talking about a scanner problem or a computer problem while using the scanner?If so; Which brand and model scanner?
  • 35 Answers
Try to reinstall windows and c if it still running slow or not it is because the system is reading some files which might be lost or corrupted so it is reading slow.
Posted on Jan 07, 2009
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Sir Iam Using HP 1007p Printer, One time i get the print in my printer, but my computer monitor "Engine scaning Error" window will be dipalyed, Pls sloved this problem in online
Laser scanner assm faulty, replace it..
If you are teck guy, open laser scanning unit check the engine motor rotation is it free or hard, lubricate it & clean the reflected glass.. fix it back and try..
Sep 20, 2011 | HP LASERJET P1005 Printer
Hi.. if a client pc is very slow where is the
Might want to check the ram. That will always make a PC run slow, but if you have a sufficient amount of ram I would say a gig for running xp. Then re-formatting and re-installing the OS will make the computer faster. Also some PC have a built in recovery partition.
Jul 19, 2011 | Microsoft Windows XP Professional for PC
Suddenly shutdown my laptop what is a problem i
Hello my friend,usually laptops when are overheating because of the processor or graphic card they start restarting or shutting down.Was your laptop warm when shut down or you was watching video or playing a game?
Feb 06, 2010 | Compaq Computers & Internet
System is too slow on booting even on playing any movies and windows media center is only suported an limited extention pls pls upgrade this..............
try upgrading the ram the higher the ram the faster your computer will run,you can also upgrade the CPU to make it run faster but your best bet would be to upgrade your ram, also scan your computer for viruses this may also be part of the issue
May 07, 2009 | Microsoft Windows Vista Ultimate Edition
I am facing a big problem(System working very slow.When outlook mail/.doc,.xlx etc).I have Dell Optiplex755 modell system,1gb ram,Os Xp with sp-2,Office2003 with servicepack3and antivirus Trendmicro...
First...you need to clean your "Windows"for unnecessary files.Search on Google for "free windows sweeper"...It a software very useful and free to use. Install the software check options in left panel and push "CLEAN". Second: Search on Google for a software for fix hidden errors(ex: Registry repair or Advanced System Optimizer) both software are 15 or 30 days free to use.....And don't forget START PROGRAMS ACCESORIES-SYSTEM TOOLS-DISK DEFRAG or (my recommendation is to use Advanced System Care.They have a free version very good....and one more thing START RUN and type "msconfig" hit ENTER and go to tab "STARTUP" and uncheck programs that you do not need to start at computer startup...After all those things you will have a new computer...more faster....more optimize....Goood Luck!
Mar 20, 2009 | Computers & Internet
My Pen drive is 1 Gb Transcend,When i format it show 4 Gb & Error
its probably a virus trying formating on windows 98 or on linux based system may work for u also check when the pen drive isnt connected properly or the usb port or connection is loose it may say a read only pen drive due to slow speed connection of pen drive to computer
Jan 19, 2009 | Transcend (589307) Media
Sound problem
hi i have e problem whith sound device i cant lesten muzic whithout it can u helpme to fin it pls
Sep 06, 2008 | Computers & Internet
Logg off system automatically .... ?
You problem lies in you operating system which has been dameged by viruses. the best way to fix this problem is to formatt your harddrive and reinstall a fresh copy of your operating system. otherwise if you have information you would like to keep you can just reinstall you operating system without formatting then you must get yourself, updated, good antivirus software and scan you entire system and delete any infections.
Jun 07, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
