Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
My 25cc string edger will start and run fine in med choke but wil
Running of my edger. wont run when choke is off
  • blueass70 Jan 30, 2009
    Hello...I am having the same problem with mine and I read that if you adjust the two screws (blind screws-no slot) out 1-1/2 turns, it should run...If you have had success in getting yours running please contact me at "blueass70@hotmail.com"..Thanks
    Problem Solver:
  • 3 Answers
High speed jet is pluged
Posted on Jan 04, 2009
Get to run
I assume you mean it bogs down when you start to pull the throttle trigger? If that's the case, you need to adjust the low side CCW about a 1/4 to 1/2 turn.
Oct 09, 2014 | Poulan Pro PP025 17-Inch 25cc 2-Cycle...
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Troybilt Engine wont accelerate
The machine is running too lean on the fuel mixture, if the fuel filter in the fuel tank is clean ( replace if needed ) then you can unscrew the H screw on the carb to richen it up, you may need a special tool to turn the screw if it is an anti tamper type.
Jul 08, 2013 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Hard to start but when i do get it started and turn the choke off it will not run
Check your fuel filter. It could be clogged. If not, it will be a problem that will require removing the carburetor and cleaning the mesh fuel strainer. It will most likely be clogged with a fine sedement. The strainer can be removed using a very sharp pointed large needle. Place the needle against the edge of the strainer and lift out. Sometimes they can be difficult but persistance is the key.That and patience.
Aug 29, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
ENGINE STARS AND THEN DIES
Try changing the fuel filter and if that dont do it there is a small screen inside the carb that usually plugs up carefully disassemble it and clean it out with a good brand of carb cleaner
Jul 20, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
Wont run in run position
if it runs on choke only and it sat up for two or three months the carb diaphragm may be brittle and not pumping fuel. install a carb diaphragm and gasket kit or try opening the high speed jet a 1/4 turn
Jul 01, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer only works on full choke
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
582 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
