Question about Xerox Phaser 8550DT Thermal Printer
Strategies on saving ink and power
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have an 8500-DN which is for home use. I currently have the printer go into power-saving mode after 30 minutes and wakeup only for print-jobs. After having this type of setting for a few weeks and a few power outages and shutdowns I noticed that the waste tray is getting kinda full even though I printed less than 20 pages.
This got me thinking that I might have the printer configured all wrong; apparently I wasted a lot of ink and power (warming up involved about 5 minutes of 1000 watt power consumption) for very little pages printed.
I am looking for the best balance in power-saving and ink saving for home use. Any suggestions especially for conserving ink since that is by far more expensive than power?
Thanks
Mike
  • altarace Jan 06, 2009
    Thanks tryit for confirming my suspiciouns about the wastefulness of this printer. Selecting between 30 and 240 minutes is not really useful for home use since most print jobs will not happen within 4 hours of each-other which almost guarantees a head cleaning cycle per print job. Is there a way to set this value higher than 240? or even better a way to stop it from cleaning the head after each wakeup?
    Also; any idea how many head cleans it takes to consume a whole solid ink cartridge? I'm guessing the printer is an "equal opportunity waster" meaning it will waste an equal amount out of each cartridge type per cleaning cycle?
    President:
  • 2,072 Answers
Here are the instructions on adjusting the low power mode.
Sadly the phaser printers are horribly wasteful.
What happens is when they come out of sleep mode or start from a no power situation, a compressor comes on and removes all the ink from the print head then refills the print head with fresh ink.
That is supposedly to maintain print quality. But very wasteful.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Posted on Jan 05, 2009
Xerox phaser 8500 cracked ink blocks
http://www.ehow.com/how_7319569_remove-xerox-phaser-wax-ink.html
Aug 23, 2013 | Xerox Phaser 8500/DN Printer
Does phaser 8560 and 8500 take same ink
The 8500 and the 8550 do use the same solid ink cartridges. Not sure about the 8560 since couldn't find information about it.
Jun 24, 2010 | Xerox Phaser 8500/DN Printer
Paper jams at front feed. noisy when starting. grinding noise
Run remove ink smears. Clean pick an feed rollers with packing tape.
Jul 27, 2009 | Xerox Phaser 8500/DN Printer
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
How to turn off the cleaning page feature in Xerox Phaser 8500
Actually what is happening is your machine is going into the power save mode and staying there for a long time.
What happens then is you get a full warmup. When the machine warms up, it will turn on the compressor and drain the resivour because Xerox wants a "fresh": supply of ink in the print head.
Its excruciatingly expensive and wasteful.
Here is something that can help. I am not sure you can completely disable the energy save mode. Thanks Al Gore...
Dec 17, 2008 | Xerox Phaser 8500/DN Printer
Infrequent use of Xerox Phaser 8500
The reason he told you that is because ;
if left on permanently the fuser unit has a lamp ( nowadays the newer ones use a ceramic) the lamp continually comes on to keep the fuser warm and ready for you to print.which may cause the lamp to burn prematurely, most business keep theirs on all day with out the sleep mode( too busy to wait to warm up),
But, when you use the sleep mode most models do not turn on the lamp ( if it does it only puts out minimal power) but keep the power ready, which is why when you go to print it takes awhile to warm up.
The lamps are very resilient and last several years before having to change.
Jul 17, 2008 | Xerox Phaser 8500/DN Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Error: 09,035.43:27650
You have a Cyan ( blue) ink stick stuck or a broken ink stick in the ink loader.
Check the cyan slot carefully, one of the sticks has not moved properly, The machine is not seeing the ink loader moving indicating a stuck cyan stick, Here is the info.
Ink stick count faults (error code 09,03x.4x) are declared when the printer melts 2.5 ink sticks without tripping the color's ink out flag. The ink out flag is used to physically count ink sticks passing thru the ink loader.
Verify that the ink sticks are Xerox 8500/8550 ink sticks. Manually verify that the ink stick are correctly loaded and are able to advance in the ink loader chute. Check for broken ink sticks which can fool the ink out (ink stick counting) sensor.
The ink stick count fault can only be cleared by powering up the printer in internal diagnostics mode. Then scroll and to the Functional menu item Clear ICS Fault.
Dec 19, 2007 | Xerox Phaser 8500/DN Printer
Phaser 8500 Ink
No. You will wind up with a bad ink loader.
Just had someone try it.
Nov 17, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8550DT Thermal Printer Logo
197 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
