Question about GE EGR3000 Gas Kitchen Range
Hot point oven will not come on
My Hotpoint oven will not get hot. The igniter element does not come on.
    Sergeant:
  • 311 Answers
You have to check voltage at ignitor while thermostat on/if 110 volts you need new ignitor.if no power will trace back to next componet.i think one side would be thermostat other netural?
Posted on Jan 04, 2009
My hot point oven will not get hot
could be either the thermostat or the heating element, 9/10 times it is the heating element.
Hope this helps
Nov 11, 2011 | Hotpoint Ovens
My hotpoint cooker blows the mains fuse when the oven gets hot
If it is a fan assisted oven, and the fan is working o/k, then it is probably the oven element insulation resistance thatr is breaking down as it gets hotter, so probably requires a new element fitting.
The element is located at the rear of the oven compartment behind a removeable cover.
Nov 09, 2010 | Hotpoint Ovens
My electric hot point oven doesn't heat properly. The top part of the heating element does not come on.
It is either a faulty element, or a faulty regulator/selector switch tha t is causing the problem.
Hope this helps.
Dec 18, 2009 | Hotpoint Ovens
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Hotpoint BU72 Cooker - Oven not getting to temprature
Lower oven has new element but still not reaching correct temperature.
Mar 16, 2008 | Hotpoint Kitchen Ranges
Hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Feb 22, 2008 | Hotpoint DY46 Style Line Stainless Steel...
GE EGR3000 Gas Kitchen Range Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
