Question about Apple iPad Tablets & eReaders
PUK CODE FOR IPAD MODEL A1337
INVALID SIM CARD
4 Suggested Answers
  • 192 Answers
SOURCE: how i can to unlock
http://optus.custhelp.com/app/answers/detail/a_id/209/~/how-to-get-your-puk-code
Posted on Sep 14, 2011
deandrwp72
  • 23 Answers
SOURCE: What's the default sim pin for my IPad Air purchased from Verizon last year?
  1. From the Home screen, tap Settings.
  2. Tap Cellular Data.
  3. Tap SIM PIN.
  4. Tap the SIM PIN switch to turn on switch_on_icon.gif or off switch_off_icon.gif.
    linote.gif SIM PIN is turned on when the switch is in the green position.
  5. Enter the current SIM PIN then tap Done.
    linote.gif The default SIM PIN is 1111
Posted on Nov 09, 2014
scottfinnell
  • 72 Answers
SOURCE: Ipad air says Invalid SIM in upper left corner? not sure what it means or to do to fix it
The most common reason for this is that the SIM needs to be taken out and reinserted. I put a link below to show how to do it. What it means is that their is a problem with your SIM card, and it might just be a lousy electrical contact issue, but it could be faulty too! You may have to contact Apple to get a replacement. Also, you must be in a country where that SIM is supported. Please read the following links.
Remove the SIM card from your iPhone or iPad
http://support.apple.com/en-mt/HT516
Posted on Jan 05, 2015
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
Save to sim card
Mr Gerald, Save to sim card. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to back up your contacts to SIM card on an Android device
https://play.google.com/store/apps/details?id=com.shao.Copy2SIM&hl=en
how do save contacts to iphone sim know it can be done
How to Save All Things From an LG Phone to SIM Card
Aug 21, 2016 | Tablets & eReaders
How do I delete unwanted books?
You could plug the SIM card into a laptop and format it. To do this you need a SIM card adapter. If your laptop does not recognize the SIM card, you know the SIM card is useless.
The SIM card adapters cost about $7.
Mar 07, 2015 | Barnes & Noble Recertified - NOOK Simple...
Jan 05, 2015 | Tablets & eReaders
How to get the cell number of a SIM card
Call to other Mobile. Or contact customer care and tell the numbers printed on sim card.
Aug 17, 2014 | Tablets & eReaders
Samsung galaxy tablet wont connect to server, says network error
Is your Samsung Galaxy Tab locked with any particular network?If so..when you insert other networks sim..it will show error messages like network error/invalid sim etc.I suggest you can approach your network provider and get the unlock code for your device.You can follow the free unlock instructions from Mobileunlockguide.com and enter the unlock code easily.This way you can unlock the device very easily.
Mar 02, 2014 | Samsung Galaxy Tab Tablet PC
Were to put sim card on karno tablet
Sim card? I don't believe it supports a Sim card. It does support a SD card for memory. If that's what you meant then it would be on the side where you can plug in your headphones. Next to the slot it should be labled.
Feb 01, 2014 | Tablets & eReaders
Sim card in a panasonic cf-h2
To insert Sim Card in a Panasonic CF-H2, you need to open battery compartment 1 and remove battery, you will see where the Sim Card inserts, place the sim card gold side up in the depression. Slide sim card down the depression toward the sim slot, slide down till it clicks in place. Re-insert battery 1. Sim card inserted.
Mar 22, 2013 | Panasonic Toughbook CF-H2ASFAZ1M 10.1" LED...
My sim card not installed
It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
Mar 07, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
John mullen
john smith
Ronald Connal
Ronald Connal
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
