Question about Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058
Miller spectrum 625 extreme plasma cutter arc won't stay and won't cut through 3/8 mild steel?
Arc starts but then quits then starts again either way only cutting about half way through the steel. I have it plugged into a 20a 110 outlet and the power setting set to 25. I have the 30a tip in the gun and the 30a drag tip in. What am I doing wrong?
  • 5603 Answers
SOURCE: spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Posted on Mar 04, 2010
  • 313 Answers
SOURCE: spectrum 2050 plasma cutter .
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Posted on Aug 02, 2010
SOURCE: can i plug my miller spectrum 1000 plasma cutter
no you idiot! the plug is different & even if you could somehow, its half the power output. Your plasma welders for the matter, have whats called a duty cycle, which plays into effect.... electrical load level....ect.
HOWEVER-- you can plg ito the same outlet as your stove, washer & dryer plugs. DON'T BURN YOUR HOUSE DOWN, The wife will kill you!
Posted on Sep 05, 2010
luis_david
  • 407 Answers
SOURCE: My Thermal Dynamic Drag Gun
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Posted on Jun 28, 2011
  • 5 Answers
SOURCE: miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Posted on Nov 27, 2011
Miller plasma cutter spectrum 625
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Cant get it to arc or blow?
cant get the plasma to give me a continous arc
Mar 17, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Spectrum 2050 plasma cutter will not arc
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Circuit board flashed resistor
Check this site out.
www.arc-products.com
1-800-770-0063
619-628-1022 Fax: 619-628-1028
service@arc-products.com
Arc Products
1245 30th Street
San Diego, CA 92154
Mar 17, 2009 | Miller Welding Tools
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters support
Plasma Arc cutting is an excellent choice for most cutting applications but it is particularly well suited for applications where speed and excellent cut quality are important. Because of the intense heat of the plasma arc – around 40,000° F compared to 5,700° F, with gases used with Oxy-Fuel torches – the cut is clean with little or no dross.
Aug 27, 2008 | Miller Spectrum 1000 Plasma Cutter...
Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER 907058 Logo
200 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
