Question about Intertherm P3RA-048K Air Conditioner
Intertherm Furnace Will not stay on
I have had to hit the reset button for it to heat. Now, I have a blinking light that indicates ''Limit Circuit Open or External Load on W.'' What does this mean?
I have had several problems with this furnace. Every year it seems we have to replace a part or two.
  • 67 Answers
Dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor
Posted on Jan 07, 2009
  • 70 Answers
Possible dirty air filter low air flow causing high temp in fire box to trip limit switch or fan motor is bad hope this help let me know if you if this solved problem I may need more info
Posted on Jan 04, 2009
Where is the limit switch on an Intertherm M1MB070ABW furnace?
it would be a safety switch up by blower assembly. typically has red reset button.
Apr 26, 2015 | Intertherm Heating & Cooling
Flame sensor
Chances are there is a problem with the heating circuit. The blinking light is representative of identifying a problem. Look on the panel to see if it explains what each blink means.
A system that has a problem with the heating circuit will always bring the blower on and it will run continuously until someone turns it off.
Also check to see if there are safety high limit reset button on the unit that can be pressed to reset. Some manufacturers install them to alert you to a problem that needs to be corrected.
Mar 16, 2014 | Coleman Heating & Cooling
Furnace will not kick on
going out on high limit which requires manual reset
Dec 15, 2013 | Intertherm P3RA-048K Air Conditioner
Furnace lights blows heat in cycle, pops sensor on blower and continuosly blows air until button on sensor is pushed back in
If the sensor knocks the unit off and the the fan keeps blowing without a flame ,the limit (the sensor is a limit comptroller that turns off flame @ a set temp and allows the fan to run until the heat exchanger cools to @ set temp) has out lived its lifetime and needs to be replaced.the button is a manual reset that once reset would allow the unit to continue to run flame and blower at the same time after having been set once, if it is an ongoing problem and needs to be reset more than once then replace the limit control (sensor) in kind. (With the same mode and set-points for the limits)
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
Intertherm mmha070
Hi, did he bypass the high limit to see if it was bad? Sounds like you are getting false codes and you have a problem in your module or main board, which ever you have. The way it is acting, saying the high limit is open but the tech says its not, I would change the board.
Shastalaker7
Nov 14, 2011 | Intertherm P3RA-048K Air Conditioner
My furnace the burners light and come on and heat up the unit. But the fan never kicks on and blows. The fan itself works because I can turn it on manually so I know it's not that. The trouble code...
The manual selection on the thermostat bypasses the fan relay. When in Auto, the fan relay turns on the blower. You are probably looking at replacing the circuit board. As far as the three blinks, on the reverse side of the front panel there is a wiring diagram and error code chart. It will give you a starting point where to look for a problem. The three blinks could indicate an open limit because the blower is not operating. Keep the blower on manual and let the furnace run normally until you can figure out what the problem is.
Feb 23, 2011 | Intertherm Heating & Cooling
I have a 90+ gas down draft furnace what burned a few minutes on and then off before turning the furnace off. The fault code would seem to indicate a Low Flame Sensor Signal. The sensor was removed and...
What you are describing would seem to indicate that the high limit switch tripped....
Check to see if there is a manual reset high limit in that heater...also recycle the power at hte circuit breaker to reset it from a lockout to see if the high limit is an auto reset...
If none of that works then the high limit may be bad or the circuit board is bad...
heatman101
Nov 25, 2010 | Heating & Cooling
Furnace main fan comes on but the furnace doesn't come on. The indicator red light blinks four times. What does this signify?
You have to get in to the main circuit board. At the bottom of the circuit board it will tell you what the flashes mean, in very small print. Read this print for you codes.
Dec 25, 2009 | Goodman GMS90703BXA Heater
Your furnace is likely getting too hot check your filter. make sure the fan is running. if you have weak air flow you may have a blocked heat transfer coil. you should have your heating and cooling system serviced yearly by a qualified company to inspect and test equipment.
Jan 04, 2009 | Intertherm Heating & Cooling
Goodman furnace 4 blinks
Ohm out the safety switches also known as the high limits usually at least two on units they look like little buttons, with two wires going to each one. An open high limit will mean the circuit is not closed and allowing for the system to complete the circuitry to fire the heat, best way to diagnose is to jump out the suspected high limit s/w if the unit runs then you have your answer, but never, never leave the high limit switch jumped w/o the switch.
Dec 21, 2008 | Goodman GMS90703BXA Heater
Intertherm P3RA-048K Air Conditioner Logo
382 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
