Question about Frigidaire Washing Machines
My Frigidaire affinity front load washer will not fill with water on bulky,heavy and normal wash modes but works fine on delicate setting
On those modes it starts a slow spin and within a few min the timer goes to 3 min left and then runs out time
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
  • blaundone
    blaundone Feb 14, 2014
    FAFW4011LW0
  • Tom Cross
    Tom Cross Feb 27, 2014
    Mine is doing the same thing!!! same model!!! What is the trick???
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Posted on May 31, 2009
localwonder
  • 6784 Answers
SOURCE: stops right before draining pre-rinse and spin cycle
HI. The first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating.
NOTE_ If the lid switch passes the examination, the culprit will be the timer mechanism.
Posted on Dec 27, 2009
Testimonial: "I didn't mean to reject it :-P You nailed it! Thank you! Matt"
Why does my frigidaire front load washer FAFW3801LW2 not work in bulky setting
Hi Rodney, I know nothing about it. Have you started it and left it be for say 2 hours?? other than that wash them twice to make sure its clean. Best of luck with it. Greg.
Apr 27, 2014 | Frigidaire Washing Machines
Affinity only works on delicate
Hello Ed - Often when a washer only works on a certain cycle, it is because the unit could possibly be experiencing a potential wiring failure, a communication with the control board or faulty timer. Let's try resetting the unit by unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the washer. If the issue persists, then at this point I strongly recommend reaching out to a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Jun 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
Not hot water EF0 code
Check for kinked or blocked
incoming water hoses, clean the incoming
water screens. If problem still remains,
replace the water inlet valve assembly
May 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
129 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
