Question about Cuisinart Grind Central DCG-12BC Blades Grinder
Can you sharpen blades on cuisinart coffee grinder
5 Suggested Answers
SOURCE: grinder blades dull
I may be having the same problem. My coffee grinder has had more leftover beans in it more and more this week, until finally today, possibly a quarter teaspoon passed through to the filter basket and the remaining beans were still very much beans. My first assumption was the blades.
Posted on Dec 25, 2007
SOURCE: CCM-16 Series Cuisinart Supreme Grind Automatic Burr Mill (Coffee Grinder)
Actually, I've never had any problems with my grinder. Got it for a very low price at Costco about 2 years ago. The switch has never failed to function and I've often slid the switch over to the left to stop the grinding before the designated time (I was in a hurry for my coffee) , but this hasn't seemed to negatively effect the function of the switch. It just keeps working.
Posted on Sep 20, 2008
SOURCE: cuisinart burr coffee grinder
The best solution I have was referred to me by a mate of mine who services commercial coffee machines.
Step 1. Remove the base of the grinder... this is actually the hardest aspect of this task... as there is one tamper-proofing screw... if you can't get the correct star-hex screw driver I recommend drilling the screw out.
Step 2. Once the base is off you will see the main shaft of the grinders motor. The shaft has a star washer set in behind hew nut, the end of the shaft has a slot cut into for a flat bladed screwdriver. Hold the nut with a pair of pliers & you can adjust the shaft positioning (& hence the burr attached to the motor) by about 3mm....
You will need to experiment to find the correct level of fineness as you require.
If you need further information send me an e-mail as I'd be happy to forward more detailed instructions.
Good Luck.
Cheers.......
Dave (dave@kingkiwi.f9.co.uk)
Posted on Nov 04, 2009
  • 547 Answers
SOURCE: My cuisinart burr coffee grinder will not turn on
This model sometime gets plugged up with grounds.
Unplug the grinder, and remove the bin where the grounds go. Look inside the grinder part where the grounds come from the grinder into the bin. This should be clear, and you should be able to see part of the grinder wheel inside. If this is plugged up with grounds, then you'll want to clean it out, but it's possible that the motor has already burned out (we killed two of them last year at my office this way)
Pour out any whole beans that are in the top part. You can pour them in a bowl to save them, you don't have to throw them away.
Unscrew the top part until it detaches from the grinder. This will take 20 or more rotations -- just keep turning it counter-clockwise.
You'll want to do this next part over a sink or a counter that's easy to clean -- you're going to dump a lot of ground coffee.
Looking into the grinder from the top, you'll see the grinding wheel in the center, and packed coffee grounds around the edges. Use a plastic knife or bamboo skewer to clean out the ground coffee. Don't use a screwdriver, metal silverware, or anything metal, as this can damage the grinder housing. You also want to clean from the bin opening. When you're done cleaning, the grinder wheel should turn freely.
Reattach the top portion, put the bin back in place, and turn the grinder on. It should turn on and spin the grinder wheel. If it still doesn't, then your motor is burned out. :(
If it does turn, then put the coffee beans back in and enjoy a cup -o- joe!
Posted on Jan 30, 2010
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Blade sharpening
you most likely cant sharpen them but replacing them is a better option. As for how, google your model # that you forgot to give us and you might find out how !!!
Dec 29, 2013 | Breville Coffee Makers & Espresso Machines
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Grinder on Cuisinart Grind and brew does not work anymore.
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee basket
Called Cuisinart - they said to remove the basket ( I unplugged and then used pliers to move the blade/shaft up and down until it wiggled loose ) ... use soap and water to remove coffee oil (the real problem) and then pour a little vegetable oil into the female end where the motor engages the grinder blade to lubricate.
May 26, 2008 | Cuisinart DGB-300 Coffee Maker
Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Jan 28, 2008 | Cuisinart DCC490SA Coffee Maker
Grinder blades dull
Sep 24, 2007 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind Central  DCG-12BC Blades Grinder Logo
634 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
