Where do I find system settings to change my usb port settings?
  • 564 Answers
You can go to device manager, click start and right click on computer/my computer and choose manage.
Posted on Nov 01, 2012
My bios can not detect usb configuration why? my usb ports can not be Used?
If you already tried to clear the bios settings of your motherboard or change the bios settings but still the same. The best solution for you is to buy a pci (Peripheral Component Interconnect) card with usb port commonly with 4 usb ports. The pci card will install on your free pci slot on your motherboard and depends with your operating system if the card will plug and play or manually install using it's driver.
Apr 22, 2013 | ASUS Computers & Internet
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Hi, I have Olivetti PR2E. Now i am using notebook, so there is no serial port at my notebook. Then i bought the usb to serial port cable. I add printer (Generic/text) cannot printing out. then i install...
Hi, what your system detecting is that the PR2E still in COM1 or COM2, if you have the driver installer set the port to USB so that the system will detect your printer via USB. Or change the port access from COM1 to virtual USB.
Jun 22, 2011 | Office Equipment & Supplies
My pc window can not recognize mp3 player
Hello
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
Nov 14, 2010 | SanDisk Sansa e250 MP3 Player
My computer is not reading it
hello
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled. Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Oct 01, 2010 | SanDisk Sansa m240 MP3 Player
Can i charge my camera from my usb port
It should charge but quite a bit slower. Figure about 4 to 6 hours for a full charge. Of course the computer has to be running to power the usb port.
You may also have to change settings for the USB under control panel system hardware device manager then select properties of the usb port. There will be an option for how much power the port will supply.
Or you can just plug it in and see if it works. Most newer ports (USB 2.0 type) support powering usb devices. Only a few older ones (usb 1.0's) won't or can't.
May 04, 2010 | IT Works 3045 Digital Camera
Keyboard doesn;t work at all. Keyboard checks out OK at another PC
Is this a USB or PS/2 keyboard? If it is a PS/2 then the port that is integrated on the board is not working. If it is a USB, try plugging it into another USB port and see if it will work. If it does not work on either port then the ports on the system board are not working. It means u're having some malfunctions on the system board itself.
If it is a USB keyboard and it is that the USB ports integrated on the system board are not working, buy and install a PCI card with USB ports. It should work then.
Mar 15, 2010 | Dell 0Y3740 Keyboard
Tried using usb to seriel adaptor but unable to read while reading 2way radio software. pretty sure its between the usb/adaptor
make sure that both the cable and the software that you are using are set to same Com ports.
Ex. the cable set to Com4, the software must be set to Com 4
To change the Com ports of the cable you just got to Device Manager under System Properties then on the properties of the serial cable there is an option to change the Com port settings.
To change the Com port setting of the software just simply go to its settings or preferences.
Jun 16, 2009 | Belkin USB/Serial Portable Adapter...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
