Question about Whirlpool Microwave Ovens
My whirlpool microwave oven model # mh7140xfz shows error F-6
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave stopped working for no reason
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Nov 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave oven
Yes, it could be. The first thing to try is a "hard reset".
Unplug it from the power line for a few minutes, plug it back in, then try again.
Let us know if the hard reset doen't fix it.
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: have a Whirlpool microwave oven, model MH3185XP. Just stopped wor
In some Whirlpool models, there are more than one fuse, and two or more thermal devices which can interrupt power to the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Please write back with more details if you need further help.
Posted on Mar 02, 2009
SOURCE: Microwave Oven "Error 1"
Error 1 = Short circuit in the MW(microwave) relay.
Maybe the relay have problems in your contacts. In idle state, the relay's contact must be open.
Posted on Aug 08, 2009
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Whirlpool microwave oven model gh5184xpq
KHHS178L KHHS179L
Possible reasons:
as needed.
the problem
blockage
inverter.
thanks
Apr 27, 2008 | Whirlpool GH9185XL Microwave Oven
My whirlpool microwave oven will not power up and shows a code f2. how can i fix it
its an error need to call technical assisstance ..thAT error ranges for faulty temp sensor/probe up to control board ....
Aug 05, 2014 | Whirlpool MH1150XMQ Microwave Oven
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
F7 Error Code On Microwave Ovens With Inverter Board
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
We have problem to remove our microwave from the wall brackets- Whirpool model MH7140XFZ-year 1999. Please give us advise how to do this?
Whirlpool maintains a library of free downloadable literature for nearly all of their products. Your MH7140XFZ microwave oven is no exception. The site contains owner's manuals, installation manuals and parts lists. Your answer will be found in one of the two installation manuals. You should review both to determine which best applies for your particular installation.
Referring to manufacturer's literature is always the best source for information - so I did not want to paraphrase anything in it - especially since it is readily and freely available.
I hope this helps & good luck! Please rate my reply - thank you.
Feb 17, 2011 | Whirlpool Microwave Ovens
Whirlpool microwave shows f-7
From the technical sheet hidden behind your control panel and online here:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Check resistance of the magnetron thermostat.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system. See “Checking
Inverters.”
6. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed.
7. If switches operate correctly, replace 1100W inverter.
8. If problem persists, replace electronic control.
9. Plug in microwave oven or reconnect power.
Sep 07, 2010 | Whirlpool GH6177XP Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Hello, I have the whirlpool microwave oven, Model ...
logic board needs replacement if it cannot be reset.
Jun 17, 2017 | Whirlpool MH3185XP Microwave Oven
Feb 11, 2008 | Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
