Question about Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520
How to unlock blade on homelite pro 21inch blade
The chain will not unlock
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: homelite 290 manual
I have to ask, does it have a chain oiler?
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your model is listed. HTH
Lou
Posted on Oct 15, 2009
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
How do i replace the chain saw blade on my homelite 3514c chain saw show pictures
just unbolt the blade cover adjust screw to loosen chain and remove simple as that p.s that is the side that the bar is on hope this helps if not get back to me
Oct 06, 2013 | Homelite ZR10926 16" Chain Saw
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
What size of file do i use for a homelite supermini chainsaw chain that has the number 25 on it?
hi there gmlysyshin
if you measure the distance between 3 chain rivets ______ then divide that by 2 to give ______
if this figure is 0.250" your chain is a 1/4 pitch chain in which case you will use a 5/32 file
to sharpen this chain this file is also used on a 0.375 ( 3/8 lo pro chain )
cheers hope this helps
pauly46
May 28, 2011 | Homelite Garden
Chain comes off of homelite electric chain saw ut43120
Make sure the blade is snug on bar. If it is too tight or too loose the chain may kick off.
Sep 26, 2010 | Homelite Garden
I have a homelite chainsaw xl but i do not know what size chain it takes how do i measure for a new chain
Hi, all you need is to count the number of blades. To do this I take the chain off, lay it on a flat serface and count them in two's. Once you have this its just a case of ordering a new one.
Aug 29, 2010 | Garden
Bought a Homelite 14" electric chainsaw. After using it for about 15 minutes, the chain fell off. Don't understand why. Manual did not have any instructions on how to put it back on. Returned it to...
chain will stretch with use...keep it adjusted...rest chainsaw with blade on block of wood (not running spark plug lead off) adjust chain by loosening side bolt/s then on inside at front adjust screw till chain is tight then retighting bolt/s lift chain and with gloves on check you can still turn chain by hand..
Aug 09, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a Homelite Pro 4620c chainsaw. the primer
take nipple assembly apart clean thougholy with engine degreaser or simular product then seal onthe inside with rtc silocone sealer l
May 21, 2010 | Homelite ZR10926 16 Chain Saw
Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520 Logo
32 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
