Question about Sanyo Televison & Video
Safe/dynamic mode appears on the screen for half a second
I can turn on the tv, the standby button goes from red to blue then Sanyo appears in red on the screen and then safe/dynamic mode appears very briefly. After this it's just a black screen, the remote doesn't do anything, not even turn the tv off and the panel on the front left of the tv does show white lights when touched but again does nothing. I have tried unplugging all leads and plugging back in and I have replaced the batteries in the remote. The tv is only 18 months old. Please help.
  • 127 Answers
You have a power supply problem.Most brand they have modules.
If you can open the back you will see a few separated Modules.You
will see a power supply module just replace it Take note of the connectorsThey have letters usualy to match the plugs.
By the away do you have any sound?
Posted on Nov 01, 2012
5 Suggested Answers
SOURCE: TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
Posted on May 15, 2008
toolkits
  • 1099 Answers
SOURCE: Tv will not turn on
This could probably means that the power relay is working, though there could be bad contacts.
Since the fuse doesn't blow, now you need to check for:
Other blown fuses - occasionally there are more than one in a TV.
Replace with one of exactly the same ratings.
Open fusable resistors. These sometimes blow at the same time or in place of the fuses. They are usually low values like 2 ohms and are in big rectangular ceramic power resistor cases or smaller blue or gray colored cylindrical power resistors. They are supposed to protect expensive parts like the HOT but often blow at the same time.
If any of these are bad, they will need to be replaced with flameproof resistors of the same ratings (though you can substitute an ordinary resistor for testing purposes). Before applying power, check: Rectifier diodes, horizontal output transistor, regulator pass or chopper transistor (if present), and main filter capacitor for shorts.
An initial test with an ohmmeter can be done while in-circuit. The resistance across each diode and the collector to emitter of the transistors should be relatively high - a few hundred ohms at lest - in at least one direction (in-circuit). If there is a question, unsolder one side of each diode and check - should be in the Megaohms or higher in one direction. Removed from the circuit, the collector-emitter resistance should be very high in one direction at least. Depending on the type, the base-emitter resistance may be high in one direction or around 50 ohms. If any reading on a semiconductor device is under 10 ohms - then the device most likely bad. Assuming that you do not have a schematic, you should be able to locate the rectifiers near where the line cord is connected and trace the circuit. The transistors will be either in a TO3 large metal can or a TOP3 plastic package - on heat sinks. The filter capacitor should eventually measure high in one direction (it will take a while to charge from your ohmmeter). It could still be failing at full voltage, however.
If you find one bad part, still check everything else as more than one part may fail and just replacing one may cause it to fail again.
Assuming everything here checks out, clip a voltmeter set on its 500 V scale or higher across the horizontal output transistor and turn the power on. Warning - never measure this point if the horizontal deflection is operating. it is ok now since the set is dead. If the voltage here is 100-150, then there is a problem in the drive to the horizontal output circuit. If it is low or 0, then there are still problems in the power supply or with the winding on the flyback transformer.
Other possible problems: bad hybrid voltage regulator, bad startup circuit, bad standby power supply (dried up filter capacitor, etc.) bad relay contacts as mentioned above. However, these probably would not have blown the fuse in the first place so are less likely.
Good luck...
Posted on May 21, 2010
budmrtn
  • 11361 Answers
SOURCE: TV will not turn on. Power indicator light is red
You either have the power supply module or back lights inverter board problem, need to narrow it down.
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: try www.shopjimmy.com or Ebay
Posted on Jun 16, 2010
SuperTech-11
  • 1591 Answers
SOURCE: i have a new 42"
I'd tell you how to repair it, but it'd void your warranty, and I never advise anyone to void their warranty, so I suggest you take it back and get it fixed or replaced under warranty.
Cheers!
Posted on Mar 15, 2011
Grundig blue screen then black after 5 seconds
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 23, 2014 | Televison & Video
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
Standby only only red indicator flash
increase the screen pot in lot,,,and power on the tv by remote, if horizontal line appears for second until tv goes to stand by...then vertical ic problem...other wise check horizontal o/p tranistor may be got short..
Feb 25, 2010 | Sanyo Televison & Video
I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
unplug the tv for 10 mins to let the tv reset then
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
Picture setting regularly changes to dynamic from standard
You need to change the option throgh the service mode.
You can not access that mode without permission from Samsung.
better to contact Samsung call center.
Nov 18, 2008 | Samsung LN-T4661F 46 in. LCD HDTV
Safe mode
The safe mode on Sanyo VCRs locks out the buttons on the machine. Try using the remote. To turn off the safe mode, look for a button on the remote labeled "Safe."
Dec 31, 2006 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
94 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
