Question about Rheem 81VP6S/430126 Water Heater
Hot Water Overflow
When I leave on vacation I turn off my hot water heater. When I return and turn the breaker back on the hot water overflow pipe dismisses water for quite awhile. I just returned and the same thing does not seem to be slowing down this time. If I turn off the water supply to the tank the water stops running out.
Rheemglas Standard Model 81V66D B
  • 2,692 Answers
Do you have an expansion tank tank  in the line leading into water heater? If not what is happening is that the water is no longer allowed to go back into the city supply.  You said that you had turned it off while you left so the water heats up and has no place to go so the preasure/ temperature P/T valve  opens and lets out the excess water from the expanded supply (heater water) that has no where else to go. It used to be that the extra expanded water just backed up into the supply pipe and back into the main. That is no longer possible in most places by the  National Plumbing code.    The answer may be to install the expansion tank into the incoming line. You can see then now at  all hardware stores where water heaters are sold.
Posted on Jan 04, 2009
Rheem 71 30d
You should be able to control hot water temperature by adjusting the thermostats. Either or both may have failed, causing heating to increase to the maximum. The "spitting" is caused by boiling water. Likewise, the pressure relief valve is operating as it should resulting in the overflow you observe. You need to get your heater serviced immediately!!
Oct 10, 2013 | Rheem Tankless Hot Water Heater...
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
Boiler losing pressure and overflow pipe dripping water
replace that leaking safety valve first
May 12, 2017 | Water Heaters
Hot water heater overflow leak
Copy following link for testing and replacing TP valve.
Do not cap off TP overflow tube, as this leakage signals problem.
Jul 29, 2012 | Water Heaters
After water is sufficiently heated up, water flow out of the overflow pipe for about 2-3 minutes. Is it normal?
Water should not leak out of water heater.
Water should only come out of the TP valve and down the overflow pipe if water is too hot, or if TP valve is bad, or if you have stacking condition.
Jul 14, 2011 | Rheem 81VP6S/430126 Water Heater
Water came out on the overflow pipe and kept running.
The releif valve will open if the water gets to hot to discharge hot water out or the relief valve is gone bad and needs to be replaced. the relief vlave protects the heater from high heat and build up of pressure from it over heating.
Feb 11, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water leaking from the base of the tank
If you'r really lucky you may find a leaking fitting on top of the water heater thats draining down inside the shell and out the bottom, otherwise its time to replace a rusted out water heater.
Nov 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hot water coming out of overflow, valves all been checked. Santon unvented heating system help!!
this wil happend with heating ??
if yes look for thermostat on boiler and turn it a little back then wil heater worming up only not to the max heating so then you do not need overflow outlet never leaking again out of overflow
Nov 08, 2009 | RTO Santon® Tankless Hot Water Heater -...
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Hot water coming out of overflow pipe on my vulcan everhot water
Assuming you are talking about the temperatur/pressure relief valve, it is stuck open.
1. Turn off gas or electric to water heater
2. Close water supply to water heater
3. open hot water faucet on nearest fixture to depressurize hot water system.
4. close tpr valve (you may have to push in on the center spine. It may be resistant to closing from sediment. If so, opening and closing several times may solve that issue.
Once you get the tpr valve closed, close the faucet and open the supply valve. If the tpr stays closed, go ahead and turn on the gas/electric and re-light pilot and turn on control etc.
If the TPR blows again, you will need to replace it. YOu can buy a new one at any plumbing supply store. Shut down the heater again, drain a bit of water out using the valve on the bottom of the tank. there is probably copper pipe connected to the TPR valve which you may have to cut or maybe can just unscrew. The TPR threads out of the tank, install the new valve (make sure to use pipe dope or teflon tape.
Jan 04, 2009 | Water Heaters
Rheem 81VP6S/430126 Water Heater Logo
381 people viewed this question
Top Rheem Water Heaters Experts
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
