Auriol clock keeps resetting its self to british summer time
My clock wont go back 1 hour and keeps resetting to british summer time
SOURCE: Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Posted on Nov 04, 2008
SOURCE: Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Posted on Dec 21, 2009
SOURCE: My clock radio wont keep
I took the back up battery out and unplugged the unit for about 20 minutes before powering the clock back up. Once I powered the clock up I re-inserted the backup battery.
Posted on Jan 18, 2010
SOURCE: alarm clock settings need changing, no instruction manual
In the top left corner there will be some bars showing that the hour anouncement is on. Simply press the minute button and these bars will go, leaving you in peace and quiet.
Posted on Mar 04, 2010
Tip
How to set the time/date (you have to do them both together)
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from British summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on British summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
on May 23, 2009 | Sony ICF-C273 Clock Radio
Tip
How to set the time and date (you have to do them both together)
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
How to change clock on a kindle fire to british summer time
Step 1: Pull Down upper Status Bar - More +
Step 2: Select Date and Time
Step 3: Select Change Timezone
Step 4: Change to your preferred Timezone (British Summer Time is +1 GMT)
Mar 31, 2013 | Amazon Kindle Fire HD
Cannot change auriol clocks to gmt
setting the time zone on a "auriol radio controlled clock" is as follows: 1: press the Down button for 3 seconds and an F will appear in upper right area:
2: press the Set button for 3 seconds and the Hour display should now be flashing:
3: adjust the time to your zone:
4: press Set to complete
Jan 04, 2012 | Audio Players & Recorders
My friend has a Auriol watch, radio control on the dial, but he has not got a clue how to set the time, it is always one hour fast, or slow i am not sure, but evan when the clocks change from summer time...
Just draw the short hand to the right value. (The short hand is normally frictionally coupled to the axis, and that action would not cause any problem with the clock function.)
But DON'T move the long hand!
Nov 27, 2017 | Watches
NO INSTRUCTIONS ON SETTING CLOCK
Good Luck x
Apr 11, 2009 | Sony ICF-C273 Clock Radio
How do you set the time
Good Luck x
Apr 04, 2009 | Sony ICF-C273 Clock Radio
Clock setting on digifusion pvrt95
Check your users manual for your digifusion pvrt95. It is not an issue with the hard drive.
Mar 31, 2008 | Computers & Internet
141 people viewed this question
 Grubhead
Grubhead
