Question about Intertherm P3RA-048K Air Conditioner
Electric Furnace We just came home to find the house curcit breaker off and the furnace won't come back on now. Is there a reset switch???
  • 1 more comment
  • crabtrap2 Jan 04, 2009
    There are breakers in the breaker box which I have closed and reopened but didn't solve problem. I am wondering if there is anything on the unit itself. I cannot see any.
  • crabtrap2 Jan 05, 2009
    Thank you dwkcool. Pulled safety disconnect and found control board under cover. 4 fuses - could tell immediately which was bad but replaced all. Working fine and now watching the snow fall with the heat going. Thanks again. Crabtrap2
  • dwkcool May 11, 2010
    there sould be breakers or fuse to the unit
  • 67 Answers
There sould be breakers or fuse to the unit
Posted on Jan 07, 2009
  • 96 Answers
There could be a small fuse on the cotrol board
Posted on Jan 04, 2009
  • dwkcool Jan 05, 2009
    glad I could help
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Furnace runs awhile then breaker trips
Electric furnace I assume- check with amp meter, if amps are below listed on breaker, replace the breaker, [check both the breakers in the furnace and in the house pannel, even if only one is tripping right now, the other(s) may start doing the same thing after you eliminate the weakest link- don't be surprised!] electric furnaces are notorius for "eating" breakers- they overheat the breakers for years then the breakers get weak and trip too easilly... if gas, post more info and I'll try to help further.
Feb 20, 2013 | Heating & Cooling
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Auto fan does not start electric furnace
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
We are past due on paying our electric bill; hence we a a cutoff in our power... though we were told we will have basic electricity... the lights are on .. but we can use the stove only if we turn the...
There should be a disconnect or switch at the furnace, otherwise you'll have to go to the Main circuit breaker or fuse panel and hope the circuits are identified correctly and turn OFF the circuit breaker or unscrew the fuse. If the panel isn't labeled, just turn OFF the single pole breakers until the furnace turns OFF.
Jan 20, 2011 | Electric Circuit Breaker Kit for Furnace
Have Challenger Type C 2100 circuit breaker in residential home electrical panel. Manually turned to off position and now cannot turn back on. Pops back to off position. Also says HACR type and common trip...
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
Jul 19, 2010 | Challenger Connecticut Electric UBITB-A230...
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
106 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
