Question about Sprint Hitachi P300 Cellular Phone
HITACHI 53SBX59B, projection lights don't line up.
HITACHI 53SBX59B, made in1999. The projection lights don't line up. You get a 3Dlike picture with a blue, red, and green outline. If you hit the side or top of the tv it will line back up for a minute or two, but then go back.
  • tennjed65 Jan 04, 2009
    got the owners manual, but it doesn't tell me how to manually adjust the convergence. It tells me to go to the magic adjust, which is supposed to align it automatically, but it doesn't do anything to fix it. How do i adjust the convergence manually?
We have the same problem happened a couple days ago everything is 3-d you can go to the magic focus there you should be able to go to manually at least we can ive been working on it for a day now but not really getting any where our tv is hitachi projection 51UWX2OB the lines were real bad making some headway but very slowly let me know if it works for you and how long it took
Posted on Jan 09, 2009
  • 492 Answers
You need to have the covergence adjusted.  Consult user manual for instructions on how or have a professional do it for you.
Posted on Jan 04, 2009
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Picture movement and lines
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Google “Hitachi convergence repair” and you’ll find many sites that will educate you on how to repair and where to get the parts needed for your Hitachi PTV.
Sep 01, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
Feb 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Picture flickers when T.V. is tapped on or struck.
sounds very much like a loose connection, i.e. a wire or solder joint, you could have a look around make sure everything is plugged in right, as for the solder joints id advise getting it proffessionally looked at as these rear projection tvs can be a lot of hassle if you slighty knock any of the 3 tubes,
Feb 25, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Sprint Hitachi P300 Cellular Phone Logo
156 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
