Question about Tablets & eReaders
Forgot the lexibook junior tablet password, how can I reset it?
I forgot the password for the lexibook junior tablet and don't know what to do next. I tried all the possible answers but nothing works what should I do next?
5 Suggested Answers
  • 24 Answers
SOURCE: COMPAQ TC1000 TABET FORGOT PASSWORD
TC1000 Password Clearing Procedure
1. Discharge any static electricity you may be carrying, it can burn up your mainboard and it doesn't take much! Remove the battery pack and place it out of immediate reach. you will be tempted to snap it back in later before it should be and this will spoil the work. Read everything before you start so you will understand. Remove the mini PCI communications/ memory expansion slot cover (2 small phillips screws, stick them to a piece of tape. When you reinstall them later, start by turning backwards till you hear and feel the threads mesh, then tighten slowly ... you don't want to strip out the threads on your frame! "Lefty loosey, righty tighty")
2. Remove the RTC battery “Real Time Clock (RTC) Battery” This is the black coated nickel sized battery tucked under the frame edge a little. You may have to remove the RAM if you have the extra slot filled to have enough room to work the RTC battery out. to remove the RAM chip pull the spring arms gently away from both sides at once and it will pop up at a 45 degree angle. pull it straight out. to reinstall it later put it back in at an angle, push it gently in then down to let the arms snap onto it and hold it in place. only goes in 1 way, note the notch. Use a toothpick to lift the black plastic film from the edge of the chip as it always tries to get in the way on reinstall. Have some patience or let someone else do it. DO NOT use any metal tools and be sure to remain static free!
Break or cut a short piece off your toothpick to make it easier to use the squared end to push and work the connector of the RTC battery plug off it's attachment. You may be able to unplug the RTC battery without removing it, your call. It connects at the white connector thats located next to the frame rail that separates the battery compartment from the mini PCI communications/ memory expansion bay. It is between (above) the battery release switch and the thumb lift depression to lift out the battery. Now, hold the power switch in the on position for 30 or 40 seconds to discharge any static. This is a good and recommended practice every once in awhile when batt is out and AC is not connected.
moz-screenshot-3.jpg3. Wait approximately five minutes.
4. Replace the RTC battery (or reconnect it)and reassemble the tablet PC except for the main battery, do not install it yet! Remember the toothpick will help you get the plastic film lifted clear of the RAM chip, work it into place at a 45 deg angle and then gently press it down till it locks. DO NOT STRIP out your cover screws, or try to get them super tight. They will strip out your frame, finger snug is enough.
Do not reinsert the battery pack at this time! Thats why you can't reach it!
5. Connect AC power to the tablet PC.
6. Turn on the tablet PC.
All passwords and all CMOS settings have been cleared.
7. Now you can reinstall the main Batt!
Posted on Apr 05, 2008
byteguy
  • 2229 Answers
SOURCE: forgot password
Tablet PCs aren't my specialty, but as long as you are running Windows XP. it should work like any other version of Windows XP.
Start up in safe mode and log on as administrator. If your computer is like most others, whoever set it up forgot to password protect the administrator profile. If so, you can log on as admin and go to users and change your password.
Good luck.
Posted on Mar 05, 2009
  • 36 Answers
SOURCE: I forgot the pattern to unlock my Cruz reader
Hi, enter wrong pattern few times and then it will ask you for your google account password :)
Posted on May 22, 2011
allinallelec
  • 407 Answers
SOURCE: forgot apple tablet password
try 0000, 1234, 12345, 1122.
Posted on Jun 02, 2012
Forgot password on cyclone voyager tablet
How to reset a Sumvision cyclone voyager 7'' - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1777470
Digital Spy
Dec 31, 2012 - 7 posts - ‎4 authors
Hi a friend of mine had a 7'' Sumvision Cyclone Voyager tablet for ... it round for me to look at last night, i tried to get the password reset but ...
Do you know how to reset a Sumvision Voyager Tablet, i ...
www.askmefast.com > ... > Screen
Cyclone voyager tablet how to reset stuk on android screen .... Sumvision cyclone voyager password reset · I forgot my .... Cyclone voyager 10 tablet factory reset.
Topic: Cyclone Voyager ' Tech It E@sy
Dec 30, 2015 | Tablets & eReaders
How do you stop demo mode on lexibook junior tablet? just bought it for xmas and wont let us do anything but keeps playing demo video over and over
Your tablet is stuck in demo mode, to reset the demo mode shut off the tablet, keep pressed at the same time power+volume up buttons, the tablet will boot in recovery move, the last selection of the menu is the demo mode feature 0n/off
Dec 29, 2014 | Tablets & eReaders
I have a lexibook junior tablet I purchased for my son it will no longer turn on nor charge. Don't know what I should do
If that was one of those 40 or 50 dollar tablets you may be out of luck, try holding the volume down button then turning it on. I do also know that some cheapo tablet manufacturers have " cheaper than buying another one " repair
Dec 13, 2014 | Tablets & eReaders
Lexibook market is in French how do I change to English
Try for reset to factory setting lol,
See video in my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 24, 2013 | Tablets & eReaders
Forgot password on azpen G7 tablet,do not know how to access tablet
turn on tablet get the password wrong and press forgot password after you tried it 5 times.once you press forgot password the tablet will reset your tablet and let you put a new password in unless you dont want to
Feb 20, 2013 | Azpen G7 Android Tablet
How do i reset my kurio 7 tablet my daughter forgot the password
factory reset true Recovery mode
vol+/- homebutton last power key
realease home key and - vol when boot
in recovery mode select "FACTORY RESET" enter
"ERASE CACHE" enter
REBOOT DEVICE-
Done
Jan 08, 2013 | Techno Source Kurio Kids Tablet With...
Tablets & eReaders Logo
3,023 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
