Question about Maytag Refrigerators
How to access and open clogged drain on Maytag French Door refrig with bottom freezer Model # MF12569 VEW
SOURCE: what is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Posted on Jul 30, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
  • 262 Answers
SOURCE: Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Posted on Jan 08, 2009
aborcass
  • 2651 Answers
SOURCE: my Maytag refrig. water dispenser & ice maker has ceased to work
there is a "control lockout" feature on the newer dispensors, ( not controlled by you(there is a control lockout feature)but I dont thinkn this is your issue.. the control lockout has somehow sensed a flood of water and for safety reasons has shut off the dispensor, the only way to reset this is to reset the control module, . You can either call for an autorized servicer to come reset, or if you feel up to it there sould be a trouble shooting/tech sheet taped to the underneath of unit, in the front right corner(behind hte kickplate)..
Posted on Jan 10, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
Maytag Fridge MFF2558VEM is leaking water from bottom of unit. Suspect a clogged drain hole. Need to access the drip pan and clear drain hole. Drip pan is not behind the toeplate grill at the front
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
Sep 11, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
I have a maytag refrig that I can not figure out how to reprogram the freezer temp and refrig temp.
https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10175444A.pdf
Page 9 how to set controls
Jul 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Maytag Refrigerator is 69 degrees
You must check the evaporator fan motor in the freezer.
Is it running?
You may need to push the door switch with the freezer door open for fan to run with drawer open.
Next check the damper in the fresh food section.
Is it open?
Air circulating through?
If not, replace your damper control and thermistor.
Feb 21, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
20 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
