Question about 2wire (1000-400108-001) Router
What is a 2 wire gate router
What do a gateway router do that a linlsys rputer don't do ?
  • 4 Answers
2 WIRE is a company that makes routers, Telus uses them to hook up television and internet.They don't appear to be any different unless you consider the fact that the ADSL modem and the router are combined into a single unit. All routers have a gateway IP, but its likely that a "gateway router" by definition may be just a router/modem combo, just a guess.
Posted on Jan 04, 2009
I need to find the WPA for this router
Go to the Command prompt and type ipconfig look what is the default gateway try to open the router page with the default gateway if you can't access the router with the default gateway way please check your wether your system configured in DHCP mode or static ip mode if static Ip change it to DHCP and and look for default gate way in command prompt if still cant able to open it you need to reset router with the reset button next to your power connector
Sep 01, 2012 | Linksys (NH1005) 5x10/100 Mbps Networking...
How do I change the password on my Linlsys 192.168.1.1 router?
You can login to the router page with ip address 192.168.1.1
Login to the router with using the admin password write nothing in the username
You can change the admin password on the last page Administration
It must be under router password.
http://ui.linksys.com/files/WRT110/1.0.04/AdminManage.htm
Mar 02, 2012 | Linksys WRT Computers & Internet
Open the setup page of the router.
Go to Administration tab.
There you will find the place to change the router password.
Change the password, confirm it and click save settings.
It will log you out. Re-login with the new password.
See Linksys router password
Mar 02, 2012 | Computers & Internet
I need the wpa key from my router so that i can get online with my ps3
Please click on START and click on RUN in that box enter CMD. You will get command mode. In that command mode type this command. 'ipconfig'. You ll get the ip address and gate way. Please close all of the window and open internet explorer in that same computer and enter the gateway ip address in that address bar. it will open new webpage. then enter the username and password of the router. in that window you can find the wireless settings and security key. If you don't know the username and the password of the router please open this link and find the name of your router in this page and take the username and the password. The Link is : http://www.phenoelit-us.org/dpl/dpl.htm
Aug 02, 2011 | Belkin (F5D7230-4) Router (587009)
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
What do I do to have my wireless working away from my Internet connection and wireless Router. I have 2 Ethernet cables one going from my router to my Laptop and one going from my Router to my Internet...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of your ISP will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly. Provided , that you have to configure the wireless enabling for both the ethernet cables and there after save the changes , after finding the 'GATEWAYS' if both the the ISP's seperately.
Oct 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
I am not able to ping the IP 192.168.0.1 of the SpeedStream 5100 Modem
Does the 5100b not have a "pingable" option? Or something about allowing WAN ping?
You might have to go into the advanced options or whatever to find the option to allow pings.
Sep 26, 2009 | Efficient Networks SpeedStream 5100 Modem
Are 2 wire gate way routers any good. I have heard both sides of the argument.
Well this is true for most of the products. If you are lucky then the device will give good performance.
Any ways, I recommend NETGEAR.
Jun 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Setting up a wireless connection between my linlsys pcmcia card and my 2 wire gatway
first insert your pcmci linksys card into the laptop, you would find a found new hard ware screen, insert the setup disk, and then follow the steps, automatically your card would be installed, once the installation is done, the wireless adapter , would detect wireless signal, try connecting to the wireless network.. if it asks for any key, look at the bottom of your 2 wire router you would find a 10 digit number, enter the number as the number as key code or password, automatically you would get connected.. if case if you have any problem , revert back ..
Nov 19, 2007 | 2wire HomePortal® 1800HW Router...
2wire (1000-400108-001) Router Logo
133 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
