Question about Electrical Supplies
Kingcraft 3250 generator instruction manual - Electrical Supplies
2 Suggested Answers
  • 1388 Answers
SOURCE: I have a 3250 watt Kingcraft generator that won't
Always troubleshoot with new sparkplug. Remove the oil sending unit connection from the coil. The coil should work without any wires connected. Usually the only connections are oil sending unit that will short to ground when low oil condition and other wire must be kill wire to on/off switch. Use carb cleaner spray directly into the carb with air filter removed and choke off as fuel supply. Just a short spray and another short spray after a couple of pulls. If engine wants to start you will need to keep spraying cleaner for engine to continue to run. If engine wants to run, replace fuel with couple gallons of premium fuel to get it going. Hotter fuel will help if the compression is low. Good luck
Posted on Aug 24, 2011
My 3250 watt will not send out any power. I have checked the reset.
Craig, The loss of residual magnetism may be your problem.You may have to flash/magnetize the generator. There are a few methods of restoring a generators residual magnetism. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fixing generators that have no output voltage
Flashing the Field on Honda EM 5000S Generator
Diagnosing Generator That Has No Power Output
Troubleshooting Generator with No Power issue
Apr 18, 2016 | Electrical Supplies
Where can I get a wiring diagram for a 3250- watt generator?
go google and type in-- schematics wiring diagram for watts 3250 generator set-- and if one is available it will be pdf version download
Jan 04, 2016 | Watts Electrical Supplies
Powermate generator 3250 runs for hours then chokes out runs rough
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Oct 27, 2012 | Powermate Portable Generator: 3250-Watt...
Need MAGELLAN 3250 GPS MANUAL
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks.
Nov 26, 2011 | Magellan Maestro 3250 GPS
Aug 24, 2011 | Generac Power Systems Generac 0057890 3250...
What is 3250 wattage i am looking at a gaggia machine to buy and it says it is 3250 wattage will i need special electrity power thanks
Hello and Welcome to FixYa!
Please explain your query a bit more... What I understand is that you need to know what that 3250 W means. Actually this the power (approximately maximum) that can be generated using that equipment... Every electrical equipment consumes certain power e,g. Ceiling fan ~100W, Iron ~1000 e.t.c. You wouldn't need any special electricity power as such.....
Regards....
May 24, 2010 | Briggs & Stratton 3,250 Watt 6.5 Hp...
Electrical Supplies Logo
166 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
