Question about Frigidaire Washing Machines
Sku7401fdp frigidaire front load washer
Does not fill with water front controlls stop and start tried to unplug thinking it might reboot itself checked hoses for water flow etc.
RescueTech
  • 145 Answers
SOURCE: Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Posted on Dec 15, 2008
localwonder
  • 6784 Answers
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
Posted on May 24, 2009
  • 4 Answers
SOURCE: Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Posted on Dec 22, 2009
cpldw48
  • 211 Answers
SOURCE: GE washer not starting
fill screen are clog with dirt
Posted on Apr 25, 2010
  • 1417 Answers
SOURCE: I have problem with a frigidaire front load washer
First of all put off the machine from the main power supply then pull out the wire from the wall for some time then put it on again reset the program on the washing machine and operate it but if the the problem remain then you can get back to me for further solution.
Thanks for using fixya.
Posted on Nov 06, 2010
Frigidaire front load washer FTF2140 upon start it began filling and then turn off, did this everytime. Unplugged it and the same thing happened. Now the lights stopped coming on and it does not work.
Good Morning Heather,
I understand that your Frigidaire washer, model# FTF2140, begins to fill and then turns off. You unplugged it, trying to reset it, and now the lights are not coming on and your washer is not working. Since you have already reset your washer, by unplugging it, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your washer not working is. Hope this is helpful.
-Best Regards-
WP
Apr 29, 2014 | Frigidaire FTF2140FS Front Load Washer 10...
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Fridgidaire Affinity AFT6500GG won't spin or fill up.
Check the hose from the drum area to a fill control valve. It will be a small hose. If it is clogged with lint, the control valve can't work. Try to undo it at both ends and rinse it out.
Apr 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire washer starts to fill then stops
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
May 02, 2008 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
