Question about Weller TC201T: Soldering Iron For Wtcpt, 42 Watt
Rewireing a handle
I got a second hand handle for a tc201 but it had been repaired but was not working. I opened it up ant the wires had been re spliced badly so I respliced them but the head came off and the wires pulled out of the connectors. I dont' remember which wires went to which connectors. THe is a green, black, and a white. Do you haveve a diagram?
Thanks,
Andrew
  • 33 Answers
Black goes to gold white to silver well guess you know where green goes now
Posted on Jul 07, 2009
I have a gm- pontiac 2004 grand prix and the wiring to my headlights is all messed up. Needs to be completely rewired. I need headlight wiring diagram for this. Where can I find the wiring diagram?
if it is that bad , go to a wreckers / junk yard and get the full wiring harness and replace the existing harness
wiring diagrams are in the workshop manual available from ant auto parts shop
Oct 19, 2016 | Pontiac Cars & Trucks
Need a repair manual for U6476- Self Propelled WindTunnel Bagged. On/Off switch broken.
You don't need a manual for this.
Place the handle drive lever in the locked, off position.
Remove the 2 screws for the handle them remove the handle, you may have to give it a good knock from the front with the heel of your hand. You should now see the front of the switch.
Remove the bad door and set a slide.
There should be a tool caddy at the top front of the unit now, may or may not have a clear door. Remove the tools and locate 3 screws if there was a turbo hand tool, or 4 screws without if 3 attachment tools.
Remove the tool holder and you will see the wiring and switch.
There are 2 kinds of switches; one with clips and one with wires coming directly out of it.
It would be helpful now to take a picture of what you're looking at for reference and ease of putting the wiring the new switch in place.
Remove the clips from the old switch or disconnect the wires.
You can now remove the switch from the body by pushing the clip on the top and bottom until it slides out the reverse side where you first removed the handle.
Push a new rocker switch into place, rewire with clips, or wire nuts according to the picture, drawing, scribble or mental note you made and reverse the rest of the steps.
When you are finished, slide the drive lever to on and you're ready to go. It's a good idea to check the motor filter under the bag, the long side filter and replace the flat belt if have not done previously in the last 6 months. Good luck.
There is no manual but here is a parts break down to see how things fit together. http://c.searspartsdirect.com/lis_png/PLDM/M0605111-00002.png
Oct 29, 2013 | Hoover Vacuums
Overdrive light turns on and off
If it works ok then leave well alone ,this is not the first time i have come across this on a auto box but then not many autos around this area but i do know that if it works then dont play as the only one that i say that had been repaired cost a new computer ,well it did get sent to the frd dealer by a customer who bought the car from a second hand car dealer as it was a auto but they wouldnt pay for it as the car wasnt brought back to the car dealer for repair but taken straight to a ford main garage and we all know how they like to invent imaginary problems with main dealer prices ,most likely cause is the computer but it could be fixed by rewiring the switch straight to light for a hours work and a length of wire ,but the new computer job ?? and the car dealer paid up for good customer relations even though it was in the sales contract that the car had to be brought back and i would have rewired it .
May 06, 2012 | 2002 Ford Focus
Motorguide model ht24 looking for wiring diagram to rewire switch
If the insulation is burnt off the main wiring you have a severe short. DO NOT TRY TO USE. Unless your a qualified electrician or motor repair tech, take it to one to have it repaired or by a new one.
Jun 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
The handle was getting hot and we opened the handle and the wires were melted around the switch. I need a part number for it. All I have seen are 2 wire and this is a 3 wire. Thank you.
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Nov 29, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Rewireing 93 harley davidson FXLR to 96 Handle bar
On the handlebar switches, Harley hasn't changed the color code scheme very much over the years but you really need a good schematic to know exactly how they are wired up. If you can find either a Harley service manual for a 96 model or a Clymer's manual, it would be helpful. I have a schmatic for a 94 FXDWG that should be alright for your 93 FXR but you need a schmatic for a 96 model bike.
Oct 07, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Rewiring, changing ape hanger handle bars to std
Try looking up Powersprtseast.com They have a parts fische you can use and though not in color itself may have colors labled on diagram for wiring harness.
Oct 02, 2009 | 2001 kawasaki VN 1500 Vulcan Classic
I was pulling my car radio & think i might have disconnected it. how can i fix it?
Check your fuses. Wiring is like plumbing.  Follow the feed.  Need a lot more information but just plug it back in if it's a harness.  It's it's just spliced together then you have to check each wire by disconnecting and rewiring properly.  Rewire while car is off turning to Acc after each wire.  Start with power, ground, pow ant, to verify connectivity.  Once power is on start with speaker wires.
Sep 09, 2008 | Car Audio & Video
Weller TC201T:  Soldering Iron For Wtcpt, 42 Watt Logo
395 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
