Question about Kodak i40 Path-Through Scanner
Tdd:86 sense:00:00:00 text: - Kodak i40 Path-Through Scanner
3 Suggested Answers
SOURCE: kodak i260 svanner not working
You have to clean both CCD& sensor.Then try to caliberate the scanner. If caliberation happened scanner is okay. After cleaning caliberation not hapening change imaging guide or lamp. in this error imaging guide having problem
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: tdd: 89
This sounds like a sensor issue, try cleaning the sensors, DO NOT use compressed air. Also try recalibrating the scanner. If all fails it may be a bad sensor, call kodak 800-822-1414 and they should be able to assist you.
Posted on Sep 15, 2011
Tdd: 1
Check the white patches on the underside of the Image guides make sure they havent been damaged or are dirty can also get the error if the guides are badly scratched
Jul 02, 2014 | Kodak i1440 Pass-Through Scanner
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | LG GSA-T20N DVD±RW Dual Layer Burner
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Tdd: 89
Feb 25, 2009 | Kodak i260 Duplex Color Scanner
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Kodak i40 Path-Through Scanner Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
