Question about Neff Dishwashers
I have a neff s9151f dishwasher (integrated) last night it was working this morning it will not turn on. I have checked socket, plug and fuse all working? Is there a reset button or can you suggest what could be wrong?
bigg t
  • 640 Answers
SOURCE: Diplomat dishwasher blows fuses
I would disconnect the heater then run the unit.If it runs the heater is bad,if the fuse blows again the motor is most likley bad.make sure there are no water leaks.let me know.happy holidays
Posted on Dec 06, 2007
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
  • 50 Answers
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
Posted on Feb 26, 2009
jan mczeal
  • 632 Answers
SOURCE: 'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Posted on Oct 18, 2009
  • 3 Answers
SOURCE: Diplomat ADP8352 Integrated Dishwasher
I have the same issue how did you fix it?
Posted on Aug 13, 2010
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher
its quite common for the interferance filter to fail on these models its situated in the base of the dishwasher connected to the mains block usually when they fail you can see black dust around it,
Nov 15, 2008 | Neff 24 in. S5456 Built-in Dishwasher
The dishwasher is not letting water in....it sounds like the pump is trying as per normal, but no water is coming in. it is very difficult to pull the dishwasher out to check the water tap, however,tap is...
suspect you can hear the drain pump running and the reason is that there is water in the bottom tray - ie you have a leak.
for a tempory repair, remove the kick plate at the bottom front and mop out the water from the bottom tray then see if appliance operates.
then find the leak!!
Jul 11, 2008 | Neff Dishwashers
My dishwasher does not turn on
check socket is ok - plug in something with a light into the same socket as an easy way of checking. otherwise go to where mains terminates on the appliance and check power is actually present - you will need a multi-meter
Jun 19, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff integrated dishwasher
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
