Question about Dryers
Replace thermal fuse samsung dv339aeg/xac dryer
Jimster
  • 240 Answers
SOURCE: replacing thermal fuse on dryer
Would need to know what type of unit you have and a model number. On most Kenmore and Whirlpool models they are mounted on the heater box itself. Depending on the type it could be inside the rear panel, or mounted on the floor of the unit. On Frigidaire and other models it mounts to the element case in the rear. Maytags also mount to the element box on the top left inside. Most of the time they have a couple of different looks. On Whirlpool and Kenmore, they have 2 wires running to them, and usually sit away from the thermostat. If its inside the rear panel of these units, it will be towards the top by itself, and could be white or black depending on the age, round or sqaure. On GE, Frigidaire, and their look a likes, it will be small and round, with two wires going to them as well. Most of the time these are metallic in color. Maytags can be black or mettalic, and sit on the sides of the boxes. If this doest help you, please get me the model number and make of unit, and will tell you right where its at. Good Luck!!!!!
Posted on Feb 03, 2008
kachbibi1
  • 979 Answers
SOURCE: electric dryer wont start
Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
Posted on Feb 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: no heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
Posted on Apr 13, 2010
SOURCE: Maytag electric dryer Model-Pye2300AZW did
The air flow past the thermal fuse is too hot. The air flow cools the heater coil area. Check the air passages from the lint filter to the heator coil housing for lint balls blocking the flow and letting the area around the fuse get too hot.
Posted on Dec 01, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio model WED6200SW1 clothes dryer
There are two thermistors (thermal sensors) in this dryer; one is the outlet thermistor located on the blower housing and the other is the inlet thermistor located on the heating element housing as an integral part of the high-limit thermostat.
These thermistors are negative coefficient type and monitors the dryer temperature on their locations according to their resistance which varies inversely with the temperature. The resistance drops as the temperature rises and rises as temperature drops.
One or both of the thermistors has an open connection or high resistance which makes the electronic control board thinks that the dryer temperature is low no matter how high it is. The electronic control board then doesn't cycle the heater relay and continue to turn on the heating element. The dryer temperature continues to rise and this blows the thermal fuse.
Make sure the thermistors are connected snugly. Remember that loose or open connection means high (infinite) resistance which makes the electronic control thinks of low dryer temperature. Measure the resistance of each thermistor then refer to the tables below. Replace the thermistor if the resistance reading doesn't comply with the table.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 02, 2011
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
My Samsung electric dryer runs but doesn't get hot
Clothes dryers usually have one of three issues when they fail to heat.
Taking a good electrical meter ( with ohms readings), check first the heating element.
If it checks good, then try all of the thermostats and the fuse. (There may be as many as 5 thermostats.)
You will need to unplug the wires off of each of these items that you are testing before you test them.
Whilst you are looking, be sure to test the two hot leads from the circuit breaker box, because one of the two hot lugs is for the machine operation, one is for the heating element.
God bless your efforts.
Jan 19, 2016 | Samsung Dryers
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
Mar 18, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dryer dv339aeg has no heat
Does the dryer light and go out? Does it try to light?
Oct 31, 2012 | Samsung Dryers
Samsung dryer not heating
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Mar 09, 2012 | Samsung Dryers
SAMSUNG DRYER NOT HEATING
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 16, 2011 | Samsung DV218AEW Electric Dryer
Not heating
Is there power to your heating element. It is probably not working.
Feb 27, 2011 | Samsung DV328AE Electric Dryer
Samsung dryer blowing thermostats, constantly
you may need to replace both thermal fuses and or the heating element itself but check to make sure you have the proper temp rating for the thermal fuses
Feb 20, 2009 | Samsung DV337 Electric Dryer
Dryers Logo
296 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
