Question about KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher
Whats the secret to getting the chopper unit back into the unit. There Tip was to use a small wrench or pair of pliers to compress the spring and align the unit. However , even with it fully compressed , the angle is right and it dosen't want to line up . I know to get it off, they advised to pull up. So it must be the opposite to replace it. I've been trying!!
    Sergeant:
  • 311 Answers
Its spring loaded,so take a small tool and hold back as you insert back into mount.God bless,tom
Posted on Jan 04, 2009
Simpson Silencio 850 dishwasher,model No. 52B850SH A lot of times after a wash cycle has finished the dishwasher does not empty out all the water and leaks out water from somewhere onto the floor in front...
Hello.
Is there a puddle in front of your dishwasher? Often this is a relatively easy problem to solve. At best, all you need to do is tighten a few fittings or level the dishwasher so water doesn't slosh out when the machine is running. At worst, you may need to replace a door gasket.
Instructions
Tools Needed to solve the problem.
Worm-drive Hose Clamp,Adjustable Pliers,Adjustable Wrench, Replacement Door Gasket, Screwdriver,Small Level
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Thanks
Oct 30, 2011 | Dishwashers
Tip
Ref: Poor cleaning or noisy pump on Whirlpool or Kenmore dishwasher. April 25,...
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
More dishwasher links
flashing_or_blinking_green_clean_light_7
general_dishwasher_cleaning
Hard_water_calcium_white_powder_build_up
on Sep 29, 2010 | Dishwashers
Sometimes after a wash cycle which has cleaned the dishes etc my Simpson Silencio 850 dishwasher does not empty out all the water and also leaves lots of water on the floor in front of the machine. How do...
Hello.
Instructions And Tools Needed to solve the problem.
Thanks.
Oct 29, 2011 | Dishwashers
How do I put the replacement chopper assembly back in place on a KUDP01?
If you slip a pair of needle nose pliers between the cutter and screen of the chopper so that is pulls the cutter away from the screen this will allow you to position the chopper back in place. Make sure the molded side of the screen is facing down and its easier with a lot of light so you can see. I have installed many of them and it is a little tricky. Hope this helps.
Sep 01, 2011 | Dishwashers
Water leaking at the bottom of the door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
I also can't get the chopper cover off my dishwasher.
My chopper cover was held in place by two screws, but even after removing them I found I needed to use a pair of 'channel lock' pliers to grasp the plastic cover and pull it up and off. Yours may just be stuck from a few years of use and thermal cycling.
Putting the whole thing back together was an equal joy...
Aug 23, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Jan 03, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Kenmore 655 ultra wash built in dishwasher
Possible problem is that the chopper/cutter filter is plugged. This prevents water circulation and therefor no water is available for cleaning.
Solution:
Remove the dish baskets.
Remove the bottom cleaning arm - Rotate the centre post and the arm can then be removed.
Remove the conduit that feeds the upper arm(s) - Remove screws, one at the back and one at the top. Rotate the whole assembly 45 deg right and lift off of the centre post.
Remove 4 screws in the plastic assembly and lift it off of the centre.
Remove 1 screw at left front (Under assembly just removed). Lift off the plastic cap which covers the cutter/chopper. Remove the chopper. It is on a spring loaded pin. Pull the cutter foreword while lifting the filter disc straight up. Thoroughly clean the filter disc - a knife will be req'd to scrape in clean.
Reassemble in reverse to the disassembly steps.
May 05, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore elite dishwasher
If this is a rounded cover you need to use a flat blade screwdriver. Make sure the screw is out on the lt side, then insert the screwdriver on the rt side where you see the tab/slot. gently press the screwdriver to the rt to pry the cover out. The chopper will come out easily, going back in is tricky. Use a 1/2 inch open end wrench, compress the spring and insert the wrench between the blade and the screen, then put the chopper back in.
Jan 31, 2008 | Dishwashers
KitchenAid 24 in. KUDI01IL - Multiple Color Free-Standing Dishwasher Logo
108 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
