Question about American Standard Home
Whirlpool tub sprays water everywhere
American standard hydro massage jet tub has too much pressure and sprays water everywhere
  • 659 Answers
SOURCE: We have purchased a whirlpool tub model #
Some jets you can stick your finger into the jet its self and move it in 360 degrees. Others have a notched round trim piece that when turned counter clockwise, will loosen the jet where you can manipulate it as described above. You will need to retighten it after your done so it doesn't end up the same way. If you have trouble, you may want to use a little spray lubricant on it so it will loosen.
Posted on Mar 31, 2009
  • 80 Answers
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Posted on Sep 19, 2009
  • 80 Answers
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Posted on Mar 26, 2010
uspartscente
  • 717 Answers
SOURCE: I have an American Standard
You can find replacement jet trim at the following source.
US Parts Center
Posted on Feb 01, 2011
timbadger21
  • 64 Answers
SOURCE: there was no owners manual
google its online it should show u
Posted on Jun 03, 2011
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
One of the "Air Volume Control" valves shoots
you can change out the complete air control valve. One thing i would have you do before changing that out is to make sure all of the jet faces are turned on. to do this turn the face of the jet clockwise. this will let the maximum amount of water come out of each jet face.
Sometimes if there are adjustable jets in the tub and they all get shut off, it will force the water that should be coming out of the jet faces back through the system and out the air control knob if it is open.
Just to check. that may not be the case....but...that would be cool if it were.
Jan 20, 2011 | American Standard Colony Hydro Massage...
I have an american standard jet tub, but i lost
Mar 13, 2010 | Home
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
We have purchased a whirlpool tub model # 1714019020. It has side jets & 4 jets at the back. Can you tell me if there is some way to adjust the back jets or to turn them off as they spray water everywhere...
Mar 31, 2009 | American Standard Home
Home Logo
162 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
