Question about GE 25GT511 25" TV
Missing speaker? I recently got this TV and noticed it had sound only coming from the right speaker. I then took it apart to find only one speaker, although there are places for two. Is this supposed to have one or two? If two, where can I get one (with the wires) for cheap?
  • 398 Answers
You have a TV with mono sound, and those sets only have one speaker. The same cabinet is used for the sets with stereo sound, which is why there are spaces for both speakers. Your set does not have a second audio amplifier to connect another speaker to.
Posted on Jun 26, 2007
Pioneer VSX-1015TX 7.1 Receiver AMP ERROR I just recently started getting this AMP ERROR message when I try to change input sources, it does not matter which source I click on, for example, whenever I...
I would recommend checking your speakers polarity ( + on the + - on the - ). Also check to make sure the wires are not touching each other where they connect to the speaker or amp. Also check your input connections if you are not using HDMI or Optical. Worst case is you have to send it in to get serviced. Hope this helps
Mar 15, 2011 | Pioneer VSX-1015TXK Receiver
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
Can not get sound to work when watching TV
you need to get the optical digital audio cable
Dec 23, 2008 | Amphion Mediaworks T342 System
NO SOUND - FRONT LEFT AND RIGHT CHANNELS
Is your respective speaker A or B selected? Is tape mon selected?(turn it off) Need more info on what all components are involved...accordianman
May 01, 2008 | Yamaha RX-V661 Receiver
SPEAKER FRONT RIGHT NOT WORKING?
ive got the same problem but with my z5500
wonder what it is?
Mar 16, 2008 | Logitech Z-5300 Computer Speakers
Fuse
dam right he did m8 robing get report him 2 the police that is class as theft an don not let him in again good look ... mjoutlaw@hotmail.co.uk
Jan 28, 2008 | Hitachi 51F500 51" Rear Projection...
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
Repetitive dull thumping noise
You're in the UK, right? Try unplugging the set from the mains and let it sit for ten to fifteen minutes. Are your speakers built in or detached? How long has this been happening? Have there been any changes recently that coinside with the problem? Are there any other audio/video devices connected to the set? If you have other devices, does the problem exist when they're in use? The clicking noise sounds like a relay that's searching for another device or input. Check the audio settings on the menu to see if something has changed. Hope this helps.
Nov 19, 2006 | Panasonic TX-28DK2 TV
Televison & Video Logo
55 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
