Question about Mitutoyo Measuring Tools & Sensors
How to read a starrett no.643 dail depth guage?
3 Suggested Answers
rick_stokes_
  • 61 Answers
SOURCE: My model 449 starrett depth mic turns hard, how
Are you aware of the lock nut that keeps the barrel from turning? There is a knurled ring next to the base that rotates to lock and unlock the barrel with a clamping action. Check that this is not causing the problem. Turn to left to unclamp.
Posted on Oct 15, 2009
rick_stokes_
  • 61 Answers
SOURCE: How do I calibrate a Starrett model 449 depth
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
http://www.mytoolstore.com/starrett/micro029.html
Posted on Oct 30, 2011
Changing the location of the decimal point on digital Starrett Internal Mic's
im not too sure what your asking, all imperial starrett id mics read 3 place decimal you will have the inch number that is set by you for the job and then the mic gives you the next 3 numbers IE 4.250
Jun 06, 2014 | Starrett Measuring Tools & Sensors
Have 763 bobcat loader keeps locking up with the sencers disengaging have notice the voltage guage going up to 18 volts at same time where should i start looking to fix this
Hello I have a 763 highflow bobcat all gauges read good I lock down the bar and go and it locks up about like the park brake is on but its off I can 10 to 15 foot and bam it locks up if someone has a idea id sure try whatever thanks.
Jan 09, 2013 | Clarke Bobcat 643
How do you set a 722 starrett digital caliper to zero.
Just ran into the same problem. Bought a caliper at a garage sale and it needed new batteries. When i put them in it was reading .006. I held the M button down for 2 seconds and it reset to .000
Jun 16, 2012 | Starrett Electronic Caliper
How do I calibrate a Starrett model 449 depth micrometer?
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
My model 449 starrett depth mic turns hard, how can I fix this?
Oct 15, 2009 | Starrett 50443 12 Machinists' Improved...
Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Jul 07, 2009 | Boating
Sudden change in oil pressure gauge
DIAL IN CAB COULD BE AT FAULT, NEED TO GET ANOTHER DAIL GUAGE AND CONNECT TO SENDER, IF SAME COULD BE SENDER, IF STILL THE SAME, PRESSURE VALVE IN BLOCK STICKING DUE TO DIRT OR U/S, OR AT WORSE !!! ENGINE WORN, THIS WILL BE CONSTANT IN MOST CASES, FAULT IN GUAGES ARE NORM INTERMITANT.
LOTUS
Feb 02, 2009 | 1993 GMC Suburban
Checking level accuracy
You do not need to replace it. If it does not read the same when you reverse it, on one end there are a nut over and under the tube and plug assembly. Adjust those up or down until it reads the same.
Starrett Tech Support
Nov 25, 2008 | Starrett Measuring Tools & Sensors
Measuring Tools & Sensors Logo
52 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
