Question about Electronics - Others
C-P7U Cassette adapter, changed battery installed new battery. automatic cover will not open when the slide is moved to the right. How can I get tape out without damage.
2 Suggested Answers
SOURCE: JVC VHS Cassette adapter C-P7u
How to safely open Micro MC_90 cassette
Posted on Oct 19, 2010
How can we change the correction tape? We are unable to get the correction tape off. We can take out the regular ribbon. The wheels for the correction tape won't come off and we can't get below taking...
1. Use the spacebar or backspace to move the carrier to the center of the platen.
2. Open the top cover.
3. remove the cassette ribbon if installed.
4. Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, lift it up and out.
5. Pass the new tape through the left guide,behind the ribbon guide. The rough (sticky) side of the tape should face the platen.
6. Attach the feeder spool to the pin on the left.
7. Attach the take-up spool to the pin on the right.
8. Turn the take-up spool counter-clockwise until a small amount of white tape is around it.
9. Replace the cassette ribbon and close the top cover.
10. Press (CODE)+(RESET)(Q) to move the carrier to the previous position.
Dec 15, 2010 | Brother ML-300 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000
1) Use the [SPACE BAR] or [BACKSPACE] to move the carrier to the center of the platen.
2) Open the top cover
3) Remove the cassette ribbon, if installed
4)Pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen, and lift it up and out.
5)Pass the new tape through the left guide, behind the ribbon guide, and out through the right guide. The rough (sticky) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it.
9) Replace the cassette ribbon and close the top cover.
10) Press [CODE] + [RESET] to move the carrier to the previous position.
Mar 19, 2009 | Brother SX-4000 Typewriter
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Oct 20, 2008 | Electronics - Others
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
My VCR is egecting the tape with the casstte adapter.
The cassette adapter uses 1 AA battery. When you place your VHSC tape into the adapter and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink wrap has been removed from the battery
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Electronics - Others Logo
80 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
