Question about KitchenAid Ovens
Kitchen aid oven model KEBC177KSS05 serial XT2413278 stopped working after self cleaning,
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
jumptrout51
  • 3361 Answers
SOURCE: Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Posted on Mar 26, 2009
  • 59 Answers
SOURCE: self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Posted on Apr 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Posted on May 24, 2009
  • 949 Answers
SOURCE: Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
Posted on May 10, 2010
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
    Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
    Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
    Will not come on after self cleaning
    this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
    to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
    **FIRST unplug from the wall or shut off the breaker**
    *the other issue is not knowing what model you have.
    I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
    hope that helps,
    good luck
    Sep 28, 2009 | KitchenAid Ovens
    I hit the self clean button on my Kitchen aid oven and now the door is locked and the oven lights are off
    I have heard that with this model, the self clean will ruin the electircal components. It sounds like you may need to have someone test it out to find what is ruined. If I were to guess I would say its the controller board. Mine was on backorder for 2 months.
    There is a person in this link that has the same issue:
    http://www.consumeraffairs.com/homeowners/kit_stoves.html
    May 09, 2009 | KitchenAid KEBC107 Electric Single Oven
    I have a Kitchen Aid Oven. I self cleaned it and when it was clean It did not work. Can you tell me why or how I can repari it.
    there are thermal overloads in the back of the oven, if this is a built-in, you will have to remove the oven from its space and take the case off of it.
    Nov 26, 2008 | Whirlpool GBD307PDS Electric Double Oven
    Kitchen aid wall oven kebs177dssp
    call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
    Dec 22, 2007 | KitchenAid Architect Series KEBC107KSS...
    OVEN will not heat
    After reading the above, here is how I fixed my KEBS177DSS9
    I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at jodunn5555@aol.com Good luck
    Nov 01, 2007 | KitchenAid Architect Series KEBC107KSS...
    Self Clean does not work
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
    Ovens Logo
    118 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
