Question about T-Mobile Wing™ Smartphone
BATTERY DOESNT WORK
MY BATTERY  DOES CHARGE BUT LESS THAN 1 HOUR THE BATTERY IS LOW
Buy a new battery on ebay. If it still is acting up then maybe your charger is messed up or the charging port on the phone is.
Posted on Jan 09, 2009
My motorola defy shows a white light when i plug in the charger but the screen only says LoadBoot. 09.10 and Cannot program battery low.... doesnt the white light mean its charging? I've tried taking out...
If you bought it from a specific company be it thru internet or site store take it to the providers site store and if there is no water damage and item is less 1 year old factory warranty covers the phone and if you got an extended warranty they should replace it in the the store, but with factory warranty they will mail you a new one (with the exclusion of the battery) and you will have to return the old one thru the USPS at their charge.
Hope that was helpful if I can help further let me know. Please rate/vote or testify to my advice.
Wicked Angel
Nov 18, 2010 | Motorola Mobility Defy Cell Phone
How long should battery last after full charge?
Up to 9 hours of battery life after fully charge.
Nov 08, 2009 | Acer Aspire One PC Notebook
This is the second Ni-MH battery I've bought that I've used infrequently over the last year and now it doesn't hold much of a charge after I charge it. Some people say I shouldn't leave it on the charger...
Any battery should start charging for over 8 hours and then it goes down to 4 hours, however no one working on a job wait 4 hours to get the batteries charged so they start cutting time and for that it get less and less charges inside and after a while it refuse to take any charge..Drain your batteries totally, charge them over night, see if that work if not just use them tell you are done with them, and get new equipments not new battery. When buying new equipments and charging them remember never use it until you fully charge it for 8 hours and not even use it for a second before it’s fully charged... Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Drills
Trying to charge, it shows hourglass then says dissabling hand held because of low battery and shuts off, then it does it all over again
take out your battery and put it back in then try charging it again. if it doesnt work try another outlet. This means your phoen needs to be charged and either your battery needs replacing or your charger. let me know what happens. should charge it for a couple hours at least
Sep 01, 2009 | RIM BlackBerry Pearl 8100
Nokia n73
The battery is faulty or needs replacing. All rechargable batteries lose their efficiency over time meaning that they hold charge for less time. It sounds like your battery is either at the end of it's life or has a fault. If the phone is less than 12 months old, it's worth contacting the seller or manufacturer to ask for a replacement
Jun 02, 2009 | Nokia N73 Cellular Phone
Working less than 12 hours
tyr to change ur charge
May 09, 2009 | Nokia Cell Phones
Battery problems
You need to replace your battery.  When you do follow these steps to preserve battery life.
1.  Fully charge battery for 24 hours 2.  Make sure that you use the phone without charging it until the phone tells you the battery is low. 3. Fully charge the battery until it reaches full again.
The reason your battery is failing to hold a charge is a problem call battery memory.  The less power that you use off the battery the less capacity the battery has.
Jan 04, 2009 | Nokia 7270
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Motorla Slvr L7 Won't hold charge
It depends on how much talking your doing. The Slvr is known for its low talk-time battery power. My slvr would last about 3 to 4 days on a charge, unless i was talking on it a lot. sometimes i would be charging it every other day. So it really all depends on the talk-time. Invest in a car charger for sure.
Dec 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
T-Mobile Wing™ Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
