Question about Dell 5100cn Laser Printer
No Print on Paper
My printer is making a loud almost grinding noise when it prints and very light, unreadable print comes out on the paper. It almost sounds like it is trying to get some toner from cartridges. They are all near full. I just replaced the Image Drum and that didn't fix it. Dell won't help me since I bought the printer on ebay. I have searched for a repair/service manual and can't find one. That would help alot! I have searched the internet and Dell's site for this problem and can't find anything. Thank you for any help anybody can give me!
  • 3 more comments
  • Vickie Sheathelm May 18, 2007
    Thank you Oxman. That does make sense. It was very dry this winter and had lots of static around. Would that also cause the grinding/loud noise while it is getting ready to print and printing?
  • Vickie Sheathelm May 26, 2007
    Cleanded the developer and that didn't work. The grinding sound is coming from farther back in the printer. I'm not sure how to get there. I'm guessing it is a worn gear. It chunked with each color I cleaned. Any more ideas or instructions?
  • Vickie Sheathelm Jun 06, 2007
    I have the printer apart. Two of the plastic gears are worn. One is on the developer drive assembly (H6702) and the other one is on the black developer (M6091). Is there somewhere I can get just the little plastic gears? Or do I need to buy the whole assembly?
  • Vickie Sheathelm Oct 03, 2007
    I did get it fixed. It was the developer driver. The gears had worn down. There was a little pile of ground up plastic right under them. Put in a new one and it works great. It is a nightmare getting to them though! I found a site that had the instructions on how to tear it down. Whew!
  • Vickie Sheathelm Nov 07, 2007
    fenton, try this site:
    http://dcse.dell.com/selfstudy/pa_links....
    If this doesn't work, let me know what your email address is and I can send it to you.
I am having this same problem, how did you fix your printer?
Posted on Sep 30, 2009
Try cleaning the developer. This option is located in the web interface for the dell 5100 under printer settings and maintenance tabs. There are 4 options: one for black, and then the other 3 for the 3 colors. Also, you could check to see if your transfer roller is installed correctly. We had one clunking and turned out the gears had worn down. Good luck.
Posted on May 23, 2007
  • 21 Answers
It sounds like you need a new electron or electrode I forget exactly what they call it, this negatively charges the paper as it passes over the positively charged toner drum allowing toner too stick to the paper where required, the lower the negative charge is the less toner that can positively stick to the paper, creating a light black or grey print. This generally occurs with age but should not be too hard to replace by yourself, just expensive.
Posted on May 17, 2007
SOURCE:
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Why is my printer making really loud grinding noise and will not feed paper or print
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Dec 01, 2014 | HP LaserJet 1018 Printer
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
Paper is not being picked up and fed through.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 20, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Dell 5100cn Laser Printer Logo
636 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
