Question about Sharp AL-1217 Copier
Sharp 1217 paper jam
Paper jam after passing form heat roller
SOURCE: Sharp AR-M355 copier with AR-EF3 adf
With what you described it sound like the paper out sensor is not working properly, might be bad or broke. Hope that Helps... Lbcoaster
Posted on Jun 28, 2008
  • 148 Answers
SOURCE: paper feeder jams and crinkles the paper up
there is a set of stripper fingers that kiss the fuser roller and paper is jamming up aginst that area
FIX
Open the fuser section door and front door Look at the fuser roller from exit and front door If there is a wiper pad (slides in on a rod from the side of the machine) remove it and put some fuser oil on it
go to area where you find the paper folding up and observe the stripper fingers for any blockage
If there is some bits of toner on the fingers clean them with a q tip and alcohol
take your finger ( make sure machine has cooled and you have unplugged from wall) and press up against the stripper fingers to se if there is movement (some coiers have a solenoid that activates the striper fingers)
The fuser oil hels keep the fuser roller clean and keeps paper from sticking on rollers
Try the copier if this does not fix i believe you have a problem with a solenoid which will require a sevice call
If you want to observe the paper coming through the fuser rollers and seeing if the fingers activate
ou can trip the safety swithes in the doors and exits and observe
Best of luck to you
Posted on Jan 06, 2009
  • 7 Answers
SOURCE: SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Posted on Mar 23, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Posted on Jun 04, 2009
SOURCE: Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Posted on Nov 20, 2009
Sharp SF-1118 copying machine H 3 Error
This is a heating error for the fusing section, the lamps may be damaged or there could be a build up of dust and debris on the thermistors that monitor temperature. I would check the fusing section. THIS IS THE UNIT THAT HAS THE TWO ROLLERS THAT THE PAPER PASSES THROUGH AT THE END OF THE PAPER PATH. Check there is nothing jammed or damaged. you may need to replace unit.
Oct 18, 2015 | Sharp Office Equipment & Supplies
Paper jam light on
the censor that detect presence of paper in the printer has stopped working. check it if you can or get it repaired from local sevice centre......
Sep 29, 2009 | Sharp AL-1217 Copier
Jun 04, 2009 | Sharp Office Equipment & Supplies
I have a paper jamming in paper pick-up area.It dosen't make it past white plastic rlrs. Manual feed by-pass works fine .XC-830
The paper pick up rollers have lost their grip and need replaced, but I wouldn't put that much expense into fixing it. That xerox is a sharp in disguise, although supplies are not interchangeable the parts are. Common repairs for that machine is the gear on the fixing roller will break, to pick up tires dry rot and the heat lamp will blow. For the expense to fix it can almost buy a new one with more features and cost less to operate. The xerox supplies are very expensive.
Just use the by pass until something else goes wrong.
Good luck
Apr 15, 2009 | Xerox DocuColor 12 Color Copier
Continuos display of 4 and H
I am change & new fuser unite but still this code
Aug 27, 2008 | Sharp AL-1217 Copier
Jun 27, 2008 | Sharp Office Equipment & Supplies
Paper Feed Problem Sharp AL-1461CS
Can you verify the model number as Sharp AL-1461CS?
Apr 08, 2008 | Office Equipment & Supplies
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
