i used to use this pc with a wireles adapter, but now i need to plug it straight into the wall for broadband, but i was on the phone with tech support for surewest all night and they said i just need to get the pc to "see" my NIC. right now it doesnt. have driver cd, tried installing them. nothing. cd will not do autorun either. went into BIOS but cant get into the menu that allows me to enable or disable the ethernet card, i see the menu in product menu but in my bios i dont see it and therefore cannot get to it. what else can i do??? please HELP!!!!
Comments:
Jan 07, 2009
- does pc chips have a tech support hotline to call or no?!?!?! this is beyond frustrating i cant seem to find one. i cant do anything without my MoBo recognizing my ethernet card.... still NOTHING!!! PLEASE HELP!!!!!
devicemanager-> click on unknown ethernet controller ->update driver->no,.................-> select from list or ........->then click on search after driver....... then check the box that say search floppy and cd... then it should install the driver
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu...
(More)
i can't install a cpu heat sync because my mobo does'nt have the white square where you put the cpu and clip the heat symc. My Mobo has onboard amd Athlon, the only way to instal a cpu heatsync is with screws on the side, but i don't find any heatsyncs with screws .
