Question about Conair Irons
New conair fabric steamer gs23 not steaming - Conair Irons
5 Suggested Answers
SOURCE: Conair GS4 Steamer
faa3e02.jpgthis is from conair instructions included with steamer, finally found it, hope it helps some!
Posted on Jun 28, 2008
geokohler
  • 304 Answers
SOURCE: conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Posted on Jul 24, 2008
SOURCE: Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Posted on May 18, 2009
  • 38 Answers
SOURCE: CGS11DR CONAIR GARMENT STEAMER
Have you checked the float?
Sometimes that gets stuck, or collects mineral and stays in the last position.
Matt
Posted on Sep 14, 2009
My GS23R fabric steamer does not work.
Time to return under warranty. There are no user serviceable parts.
Nov 06, 2014 | Conair GS33R Compact Fabric Garment...
How do I fill the GS4 steamer?
http://www.conair.com/instruction_booklets/10pa117459_gsS4_ib%5B1%5D.pdf
Oct 19, 2014 | Conair Compact Fabric Steamer GS4
Hose
Either jammed up with limescale or the heating element is faulty. contact Conair to confirm
Feb 09, 2014 | Conair GS10RHR Deluxe Fabric Steamer
Have to hold hose high to get steam
see your instruction manual section troubleshooting and see what going on. Must be the hose can be faulty or clogged. download it from www. retrevo.com or www. manualslib.com
God bless you
Nov 24, 2013 | Conair Compact Upright Fabric Steamer GS7R
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
Conair GS33 fabric steamer spews too much water..can't be normal, eh?
Are you setting the body of the steamer on a table? If part of the hose sits lower than the steamer body steam will condense in the hose and collect in the low spot. Steam pressure will push the water out through the nozzle. If your steamer starts to sputter lift the hose so that it is completely above the level of the water reservoir and let the water drain down. Its a good idea to keep the steamer body on the floor so the hose can never get lower than it.
Feb 03, 2010 | Conair Irons
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair steamer
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Irons Logo
2,628 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
