Question about Frigidaire Dishwashers
FFBD2411NB0A just installed 2 days ago and levelled but we get water leaking through the door onto the kittchen floor. Gasket seems seated How to fix it?
catriver
  • 878 Answers
SOURCE: Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
SOURCE: maytag dishwasher mdb5000awa leaking
replace lower arm.
Posted on Jan 08, 2008
  • 1122 Answers
SOURCE: I have a Frigidaire upright
yout drain in the frig. is clogged,find the drain reservoir most times in the back top of frig. remove cover and clear it out with a hanger or shop vac,if ice is there melt it with hair dryer then claer out,hope this helps,thanks-mike
Posted on Jun 01, 2008
  • 25 Answers
SOURCE: GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Posted on Jul 09, 2008
  • 7 Answers
SOURCE: Water leaking in
did you replace windshield?
do you have a sunroof?
these are the only places water could leak.
it could also be the condensation from the dehumidifier of the AC. maybe they forgot to reconnect the hose to expell the water.
Posted on Jul 22, 2008
Maytag dishwasher leak
If it's leaking from the door, a new gasket may fix this. If it's leaking from the pump, the seal is worn out, and the repair may be too costly or difficult. If the unit is 5 years old, consider a replacement.
Aug 29, 2015 | Maytag Dishwashers
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
Simpson Silencio 850 dishwasher,model No. 52B850SH A lot of times after a wash cycle has finished the dishwasher does not empty out all the water and leaks out water from somewhere onto the floor in front...
Hello.
Is there a puddle in front of your dishwasher? Often this is a relatively easy problem to solve. At best, all you need to do is tighten a few fittings or level the dishwasher so water doesn't slosh out when the machine is running. At worst, you may need to replace a door gasket.
Instructions
Tools Needed to solve the problem.
Worm-drive Hose Clamp,Adjustable Pliers,Adjustable Wrench, Replacement Door Gasket, Screwdriver,Small Level
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Thanks
Oct 30, 2011 | Dishwashers
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Leaking
this is a huge problem for you. when you have a leak coming from the bottom of the dishwasher the machine will have to come out. but first check the door gasket to make sure the leak is not coming from there.
Oct 16, 2009 | Jenn-Air 24 in. JDB4950 Built-in...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Built in dishwasher, Kitchenaid KUD124SEWHI. Water fills properly, but runs out onto the floor when the cycle starts pumping the water out.
Sounds like the water pump is leaking or perhaps one of the hoses is broken or one of the clamps is loose.
Apr 29, 2009 | Dishwashers
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
