Question about Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE3t wouldn't drain or spin
We followed previous post & removed front panel & took white cap off and cleaned out (found gunk and a penny) replaced all (after sopping up MUCH WATER w/ shamwow (finally a good use for that hahah) started again & it seemed to be gonna work...went thru a drain & spin cycle..then stopped again. We have opened it back up...(and found the tech's manual also taped inside)...
what next????
  • 530 Answers
Does the pump sound like it grinding and makeing a lot of noise ? Can you hear the pump or does it sound like its huming? There could be something stuck in the impeller of the pump. There are 3 phillips screws that hold that pump together. if you take the pump of and the impeller is not flush with itself and looks dislodged you need to replace your pump.
Posted on Jan 04, 2009
  • 640 Answers
Ok unplug unit...take connector,,of pump .put you volt meter to connector running from unit ,and see if we have 110 volts at the pump..if we do you have a bad pump...
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
The above directions worked perfectly on my Kenmore Elite HE3. To minimize...
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite HE3t won't drain. I need to find the access panel to clean the filter. Dumb question is the access panel on front or back of washer?
The access panel is located on the front. There are two screws located at the bottom left and right of the bottom panel. Remove the screws and tilt the bottom of the panel forward and down. The pump and filter assembly will be front center. Turn the cap on the front counter clockwise and pull straight out.
WARNING...make sure you have some towels ready as there will be a fare amount of water comming out.
Dec 28, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have an error code of 5UD or SUD and the water is not draining
If you are getting an F2 error message or a SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
This solution is easy, and will take no more that 15 minutes, from start to finish, and most of that time is in the --prep-- (getting tools, towels, etc.). This WILL save you a expensive service call.
There are 3 small 9/32 hex head screws that hold the front panel on. The front panel I'm speaking of is --below-- the washer window.
These screws can be found::
a. if you have the optional washer storage drawer unit,, they can be found by opening the drawer, and observing the 3 screws (left, middle, and right side, that hold the front panel on.
or
b. if you DONT have the optional drawer assembly, then they are found on the front, bottom, of the washer, again holding the front panel on the washer.
1. unscrew the 3 hex head screws (9/32 socket or nut driver size)
2. lower/remove the front panel, and set it asisde on some towels, so as not to scratch the front panel.
3. get something now to soak up at least a gallon of water that WILL empty onto the floor.
4. observe large WHITE drain cap, at front center of washer.
5. unscew white drain cap --WARNING-- lots of water WILL drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
6. clean out the front and bottom of the filter trap. I'm sure lint, and gosh knows what else have cloged some of the holes
7. wipe out the inside of the housing for the filter trap (observe lots of -gunk- there too).
8 put back in filter trap, tighten white cap, and put front panel on washer with same 9/32 screws you took off earlier.
Now I ran a test --express wash-- cycle, just to be sure all was OK,, and it was.
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Nov 25, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
